Activating anti hi-jacking door locks
Bongo163 Mar 1, 2006
  1. Bongo163
    Bongo163 New Member
    I've got a 2004 A3. Does anyone know how to activate the anti-hi jacking locks (locks at a certain speed) other than going to the dealers?
  2. Grant
    Grant Well-Known Member VCDS Map User Audi RS3
    1,206
    118
    [Select]
    [35 - Cent. Locks]
    [Recode - 07]
    Add 32 to the current value to autolock doors above 15mph
    [Do It!]
    Other central locking codes:
    +4 One touch unlock
    +32 Autolock doors above 15mph
    +64 Window Up/Down with remote
    +1024 Honk horn on alarm arm
    The module for doing this may be under [46 - Central Conv.] for newer cars.
  3. Buster
    Buster Member
    172
    +1024 honk horn on alarm arm.
    Does it give a little honk when you lock the car with the remote cos this would be good cos I've left the car unlocked a few times when I thought I locked it. A audable signal would be good
  4. dickys3
    2,954
    [ QUOTE ]
    [/ QUOTE ]
    Yes it will give a short beep on arm.
  5. Buster
    Buster Member
    172
    [ QUOTE ]
    [ QUOTE ]
    [/ QUOTE ]
    [/ QUOTE ]
    How can I activate it then?
  6. dgannon69
    dgannon69 Member
    475
    Will these codes work on a 2002 A3 1.8T?? I'd like the idea of the windows going up on alarm activation...
    Also how are the codes entered? VAG-COM?
  7. HTC
    HTC Active Member
    3,428
    9
    Yes codes are entered via VAG-COM.
  8. dickys3
    2,954
    [ QUOTE ]
    [/ QUOTE ]
    The windows won't go up on their own mind you. You have to hold down the lock button on the remote or hold the key in the lock position until they go up.
    Generally I find that these are normally setup anyway.
