Accessing the hidden 3G MMI Menu
VRStu May 30, 2011
  1. a8 tech back
    a8 tech back Member
    198
    77 is within 5f
    Unsure what your asking, have you retro fitted 3g or activated the phone
    push to talk should work or look at address 16 coding
  2. Gsmdenis
    Gsmdenis New Member
    hi , thanks for your reply .the phone was working fine via bluetooth or direct insert my sim card into slot. my address 16 streering wheel (J527) coding is 00003E, the part no. SW is 8K0 953 568 G. should i change the code from 16 ?
    Best regards !
    Denis
  3. tcmail
    tcmail New Member
    Anyone knows about 2G? Can we enable the oil temp meter? Or there is no oil temp for 2G? Thanks
  4. clansman
    clansman New Member
    21
    Tapping the wealth of knowledge on here............what is the function of 3G ? Is it a standard fit or only available with BT and or Sat Nav ? Trying to suss what goodies to look out for when I eventually see the right car ..........................Soon I hope
  5. scoTTy
    scoTTy Active Member
    1,962
    3G simply refers to the MMI being the 3rd Generation. It's not a function in itself.
    You get better screen resolution, quicker response, 3D images on the Satnav etc etc
    3G came in with the MY2010 models around July 2009. Beware that even if you buy a car with satnav after this date it may not be the full thing as the DVD based satnav was still available. The easiest way to tell is ;
    Non satnav car :
    2G Satnav cars have the MMI rotaty controller down by the arm test.
    3G satnav cars have a little thumb joystick on the top of the MMI rotary controller.
    t.j likes this.
  6. clansman
    clansman New Member
    21
    Cheers scoTTy that has cleared the fog a bit ! I think I have a hell of a lot to get to grips with here LOL. The car I have come across is an 09 but not sure how far in to 09 it was registered/manufactured, have e-mailed the dealer to ask so lets hope he know what it is !!!
  7. clansman
    clansman New Member
    21
    This is the interior I am thinking it is only a 2G unit!?
  8. scoTTy
    1,962
    Hard to tell from that pic. You should be aware that the changes for the MY2010 cars were quite a lot. At least a lot more in any year before or since. Check out this document :
    http://dl.dropbox.com/u/3628815/Car/A4/Model year 2010 changes and pricing.doc
    Personally I'd try and get the later car due to the benefits not least the quieter wing mirrors.
    Not sure what the above one is though. I suspect an earlier car based on the glimpse of the mirrors. Also since it's a manual, if it's a 2.0T or a 2.0TDI then it's an earlier car as the later ones have Stop/Start and a button under the coin holder (the slot thing near the gear shift).
  9. clansman
    clansman New Member
    21
    Any help?
    Oh and thanks for the link............yeah I am thinking along that line too
  10. scoTTy
    1,962
    I'd say it's MY2009 but during transition there's always a few off build cars.
    Simple thing is to ask the dealer ;)
  11. clansman
    clansman New Member
    21
    He confirmed it is a 2G model, not sure if it is possible to "upgrade " to 3G ? If that is possible then could be a green for go
  12. scoTTy
    1,962
    Technically it is but financially it isn't. Once you've thrown the £3k+ at it then it's obviously worth just buying a newer car.
  13. clansman
    clansman New Member
    21
    3K !!! That's a lot of Tom Toms LOL....... I get the picture now thanks for the heads up scoTTy..............again
  14. Gsmdenis
    Gsmdenis New Member
    Anyone can help my question above ? i am still looking for this SDS function , thanks
  15. evans1089
    evans1089 Active Member
    423
    74
    I cannot access the controller.. Keeps saying there's no response from controller. Any ideas why?
  16. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group
    3,764
    661
    Do you which MMI is fitted to you car is it 3G or 2G? Can you access controller 07
  17. evans1089
    423
    74
    No, won't let me access it, looking at a couple of pictures, I think I have 2G non Nav..
  18. B5NUT
    3,764
    661
    If you don't have navigation then you won't be able to access the 5F module as it will not be fitted to your car.
  19. evans1089
    423
    74
    Oh I see! Thanks so for all the VCDS mods that require activation of the hidden menu, impossible for me?
  20. B5NUT
    3,764
    661
    It's only for MMI 3G systems, that have navigation with the 5F module installed.
    evans1089 likes this.
  21. ilknur07
    ilknur07 Member
    33
    Dear all,
    I have installed rnse to audi a4/b7 2008. I cannot do coding on 77 telephone. Vcds cannot see this option. I bought BT modul. My car has mfsw. How can I activate that option? How can I use mfsw?
    Thanks many
  22. allanmb
    allanmb Well-Known Member Team Tango Audi S3 quattro
    669
    495
    as far as I am aware, RNS-E is not compatible with the B8 cars - or at least it was never fitted to any from factory
  23. ilknur07
    ilknur07 Member
    33
    Thanks for quick respond.
    Have you got any suggestion? What should I do to use it?
    Thanks many many
  24. allanmb
    669
    495
    I would ask in the B7 section - they will be more clued up for you
  25. K3Lvin
    K3Lvin New Member
    Hi Gents,
    I am a new owner of a 2013 Audi A4 B8. I just wanted to find out about the topic at hand. You say after you accessed the VIM you able to watch a video displaying on the on board screen.
    Do you have to have a Navi installed or can this feature be added in without any extras being fitted?
    Does the normal display play the videos 100%?
  26. B5NUT
    3,764
    661
    Concert & Symphony units will not play any dvd's or video files. If you you have MMI 3G then it will play DVD's but not movies of the SD. If you have MMI 3GP then you can play both DVD's & movies off an SD card.
    Movies played from an SD card will only work if they are encoded with the correct resolution & frame rate.
    We need to know what system you have,
  27. K3Lvin
    K3Lvin New Member
    Thanks B5Nut
    I have a Audi Concert System. Is it worth keeping? Are there any tricks you guys can share with me to get the best out of it?
  28. B5NUT
    3,764
    661
  29. K3Lvin
    K3Lvin New Member
    B5NUT
