access code screen on double din concert stereo
scottie123 Apr 9, 2009
  1. scottie123
    scottie123 (●̮̮̃•̃) (●&#
    1,972
    as per title.
    it is a concert II
    does anybody know how to get in the screen that you enter the stereo code.
    when i first poweredthe stereo up, it went straight to it, but now it has been in for a while, and i havent enetered the code , it just safes
    safe 2
    on the screen
    any ideas ?
  2. Silky-S3
    Silky-S3 Is loving his new 8V S3!
    1,407
    343
    Hi mate,
    I think if you hold scan and the RDS buttons at the same time it should come up...i think...
    Matt
  3. scottie123
    1,972
    seem to be missing the rds button...............
    :hubbahubba:
  4. Hastie1776
    Hastie1776 Member
    123
  5. Hastie1776
    Hastie1776 Member
    123
    Try this for safe mode code. you will need to hold down the fm2 and the rds button at the same time untill the word SAFE flashes then the screen will say 1000. then you use the numbers 1234 to change the correct digit in the 1000. once you have the correct numbers you hold down the fm2 and the rds again together untill the word SAFE appears then your good to go.
    hopefully thats some help........
  6. scottie123
    1,972
    thanks for the info but i think this info must be for another stereo as i dont seem to have an rds button!!
    i am going to try taking the stereo out for a few hours and then putting it back in. see if it wants a code then!
  7. scottie123
    1,972
    well i left the stereo disconnected last night.
    Just plugged it in again and it is still the same.
    hmmmm i at a loss now what to do...
    i have even sat there for an hour pressing and holding various combinations of buttons to try and get the code entry screen up.
    come please,.........somebody save me bacon!!!!!
    :scared2:
  8. scottie123
    1,972
    ok i have solved what you have to do......
    basically you have to leave the stereo turned on in the car for over an hour. I just turned the stereo on and locked the car and left it.
    When i went back an over an hour later, the screen said code safe instead of code safe 2
    pressed a button and it asked me to enter the code.
    Badadbing!
    so if anyone else has this problem, now you know!
