Accelerator Reset??
Nilz Dec 6, 2010
  1. Nilz
    11,318
    870
    Does anyone know how to do this, im sure I read on here a while ago and have searched, but dont really know what terms to look for.
    Apparently the car gets used to your driving style, but the accelerator pedal can be reset to normal, so that it can auto adjust to your driving style.
    Anyone know what im talking about and advise??
    Thanks in advance
    Nilz
  2. jojo
    28,846
    3,509
    Yes nilzy, you switch the ignition to on, but don't fire the car up. Now prod the accellerator pedal all the way down and hold for 5 secs, then release for 5 secs. Fire the car up, and the throttle is apparently reset it's parameters.
  3. Imteyaz
    Imteyaz 6th Gear It's my birthday
    535
    Never knew that.... You learn something new every day...
  4. finesse
    finesse Active Member
    2,805
    lol is jojo joking ¿?
  5. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Team Akoya TDi saloon Audi S8
    15,161
    1,121
    That work on others VAG or just the A3s?
  6. Nilz
    11,318
    870
    Works on all Audi and its true, its not a joke...
    Apparently the car ECU adjusts to your driving style, so if you are driving like you have miss daisy in the back for ages, the car will get used to that, looking at it from an economy side of things, this would make sense, however if you wanted to drive it hard, it wont perform as it would if you were driving like you stole it everyday.
    Now if you do the reset and give it a go, you should hopefully have a bit more kick as its reset to standard.
    I believe it has to be done on a cold engine as well....
    Hope that helps and thanks Jo for the tip :)
    I think my car is in need of it after the way i have been driving recently.
  7. Nilz
    11,318
    870
    Jo quick question, once the pedal has been released, does the car need to be switched off then back on again, or is it a straight fire up??
  8. Welly
    Welly VX220 SC Driver :)
    10,696
    127
    You will actually here the TB resetting under the bonnet.
    Once finished, ignition off, ignition back on and go.
    It may be a bit unhappy about starting first start after reset - this will clear.
  9. Welly
    10,696
    127
  10. jojo
    28,846
    3,509
    This only works for VAG cars with DBW throttle btw guys.
  11. Welly
    10,696
    127
    Yep, cable throttle cars need the procedure doing through VCDS.
    Instructions in the link above.
  12. aragorn
    18,020
    716
    throttle body alignment is not the same as the throttle "learning" mentioned in the first post
    Alignment just ensures the ECU knows the full range of throttle operation, and has nothing to do with driving style.
  13. Welly
    10,696
    127
    So enlighten us how to reset the 'learned' positions then.....? As far as I know there is only 1 method of resetting the TB data? And this would be it.
    Ross Tech say that the TBA cycles through the throttle modes 'to relearn their positions'?
  14. Nilz
    11,318
    870
    Would be interested to read more on this please.....
  15. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Not sure.. on BMW,s throttle adaption is not the same as ecu reset, you did a sequence with the ignition key to reset the ecu...Also 20 mins with a disconnected battery did the trick
  16. jdas03
    jdas03 Member
    603
    Wow thats pretty crazy! My car is driven like miss daisy 99% of the time! so doing this reset will make it more lively and kick back more?! Brilliant!
  17. audi-tk
    audi-tk Member
    441
    nice 1
  18. Sock
    Sock Shark in a Goldfishes clothing
    576
    Has anyone actually gained a noticeable difference from this?
  19. audi-tk
    audi-tk Member
    441
    tryed it but didnt notice anything. not even a sound or anything while i was doing it
