Acceleration test - EVERYONE TRY...
imported_ZeroK66 Aug 5, 2004
  1. imported_ZeroK66
    imported_ZeroK66 Guest
    Hello all,
    My bro has a scooby and his forum is doing this test...
    Stick your car in 3rd gear and accelerate from 30MPH to 100MPH and time it. Post your times here, we can compare.
    Be itnerested to see what the 1.8Ts, the 2.8s, supercharged audi's, quattros etc etc compare on here!
    Doing mine this weekend, will post results.
    NB: DO LET US KNOW YOUR EXACT SPEC! Quattro or not, what motor etc.
    Cheers,
    Leon
  2. ajmackie
    ajmackie Member
    922
    Take it that rules me out in my non turbo 1.8!!! Don't think I can get to 100mph in my 3rd gear!!
  3. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator TFSI Owners Group Team V6 Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,503
    3,063
    [ QUOTE ]
    [/ QUOTE ]
    Although he didn't say so, I'm guessing we're meant to change up to 4th when we hit the rev limiter.
    Yes? No?
  4. Kevint
    Kevint Active Member
    1,182
    I think mine hits the red mark at just over 90 in 3rd. I'll comfirm later /ubbthreads/images/graemlins/tongue.gif
    Kev.
  5. ajmackie
    ajmackie Member
    922
    I think ZeroK66 owns an oil company if he wants us to hit 100mph in 3rd gear. must be 8mpg!
  6. ajmackie
    ajmackie Member
    922
    Also are we going to go off the inaccurate as **** speedo as we're probably only doing 92mph when the speedo says 100mph. Can you just go off the climate display or is that inaccurate too?
  7. ajmackie
    ajmackie Member
    922
    Also the turbo version should do the same top end speeds as the non turbo per gear or have they altered the gear ratios?
  8. jdp1962
    8,503
    3,063
    Maybe we should all check wind speed & direction as well, otherwise our figures won't compare with each other's.
    Just a thought
  9. Kevint
    1,182
    As well as gradient of road that we use, don't want people getting an unfair advantage going downhill.
    Kev.
  10. aagallarini
    aagallarini Member
    I've got a spreadsheet that helps calculate speed at rpm based on tire size and gear ratios. According to the chart, My S4 should be hitting 100mph at 6802 rpm. This spreadsheet has no aerodynamic figures added in, so I may be shifting to get 100 also. What RPM is the rev limiter set at in the S4? I've never hit it. Since you can really feel the power start to fall off above 6k I'm shifting by 6500 anyway so I can get back down into the sweet spot.
    My buddy might be doing that in his '02 USDM WRX with boost controller. If he's not I'll make sure he is!
    BTW, what times are they hitting on the Subaru board?
  11. imported_ZeroK66
    I think the idea is to get a general idea how our cars compare to others out there and eachother. its not a massive test/ultra accurate test.
    Just be nice to get an idea - I would simply like to see how my 2.8q compares to others out there and more importantly to the supercharged ones out there! Be interesting!
