AC on or off?!!?
selector007 Dec 13, 2012
  1. selector007
    selector007 Member
    47
    What is the answer??
    When I turn my climate control on AUTO the AC light comes on which therefore means AC is on. I always turn this off as I usually use AC in the summer not the winter. So do i turn this off or do i leave this on?
    What do you guys do?
  2. DickosS3
    DickosS3 Member
    30
    Air con helps de mist the windows in winter
    Evan@APR likes this.
  3. Sandra
    Sandra Administrator Staff Member Administrator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter Audi Main Dealer
    26,812
    9,786
    Air con works more effectively all year round imho. :) x
    DickosS3 likes this.
  4. A3Kent
    A3Kent Well-Known Member Team Daytona Audi A3 S-line owners group TDi
    1,570
    249
    Climate control gives you warm/hot air too and will keep the cabin at the temp you set it to so it's used all year round.
  5. selector007
    selector007 Member
    47
    Doesn't the air con use more petrol?
  6. Sandra
    26,812
    9,786
    Yes it does, but its not that much to be honest, think i would rather be wam and comfortable and have mist free windows than worry about a small drop in fuel consumption. :) x
  7. selector007
    selector007 Member
    47
    Can you still be warm and comfortable without the AC on?
  8. A3Kent
    1,570
    249
    Depends how cold it is pal!:think:
  9. Sandra
    26,812
    9,786
    Yes you can. :) x
  10. TimG
    TimG Active Member
    942
    45
    I rarely use my climate to be honest. Never get steamed up windows and the car still heats up the same. Only on the absolute hottest of summer days do I use it and even the I prefer the windows open really.
  11. Adam.
    Adam. Meow.
    662
    34
    AC on 24/7.
    lol @ it uses more petrol.
  12. IceHanger
    IceHanger Active Member VCDS Map User
    340
    64
    from what I can remember AC puts your tailpipe emissions up slightly, but only hinders fuel economy by about 0.1MPG or something like that...nothing to really worry about, if your vehicle is quiet old it will hit it harder as the pump gets more worn and tired, new cars your shouldn't notice
    If mines on or off still only get about 28MPG hahaha
  13. Ste_Nova
    Ste_Nova Active Member
    1,223
    47
    just leave it on, it wont use loads of fuel in winter as only the dryer is running
    i leave mine on auto 22 all the time, haven't touched it since i got the car
  14. fangio
    fangio Well-Known Member
    1,488
    175
    Do what you want!:yes:
    Drive at a steady slow speed, switch air-con on and feel the drag...
  15. chinnyhill10
    chinnyhill10 Member
    151
    Buy a car with a bigger engine! Can't feel it on the 170. On my 140 Golf you could just feel it. On my 1.6 petrol Golf you could very much feel it.
    And on the loan Fiesta I had the other week it felt like someone had filled the boot with concrete. I don't know why they bother to put aircon on cars with tiny engines if they can't cope.
  16. CHEZ
    CHEZ moderately amusing Supporter
    4,171
    839
    your audi aircon/climate control is designed to be ran permanently, once you start turning it off and/or using the econ function, thats when problems start with it!
    just leave it on and be comfortable! :happy:
  17. FranA3
    FranA3 FMDETAILING Regional Rep Site Sponsor Gold Supporter Audi A3 Team Brill Red
    7,236
    331
    i leave mine on most of the time it doesnt really put alot of drag on apart from when its on LO for the first 10 mins then its fine just leave it on as said it helps to demist windows and keep the system running as it was designed to do
  18. fangio
    1,488
    175
    It still creates the same power drop!
    And wears the compressor out much sooner.....
    As long as it's run for a while each week it'll be fine.
  19. Ste_Nova
    1,223
    47
    the compresser only runs when its needed, in the winter that will be not much
  20. Ste_Nova
    1,223
    47
    i tried that today, i set the cruise at 20mph and switch the aircon on and off, it made no difference
  21. Ste_Nova
    1,223
    47
    why would you put it on LO?
  22. Ash187
    7,490
    742
    The climate control works regardless if the ac is on or off.
    The car will always try to keep the temp at the number you have set it as long as the auto button has been pressed. It's only when you play with the amount of air coming into the cabin (+ & -) that the actual 'climate control' goes to manual adjustment. I quite regularly set the heat i want, press the auto button and then press the e-con button (cars before 2009 dont have an ac button) so I have automatic heat regulation without the ac running
    Also if you press the window button on the left side of the unit then the front window demister turns on which also automatically turns on the ac... And I use that every morning.
  23. Kash.
    Kash. New Member
    20
    i just leave mine on auto all the time and let it do its thing.
  24. IceHanger
    340
    64
    lol Yup modern cars you should feel no difference, if you do the compressors fooked or more likely your **** is lieing, even on the dinky 3 cylinders it should not hinder performance! In the past on say a a 1996 Fiesta you could feel it but with technology now it makes bugger all diff unless your butt dyno can detect fractions of a kW, Atmospherics effect it more lol
  25. Ste_Nova
    1,223
    47
    why???
  26. fangio
    1,488
    175
    The compressor clutch engages as soon as you switch air-con on and stays on until you switch it off. The 'econ' button means just that; economic running with compressor dis-engaged. Even the manufacturers know they use more fuel!
  27. Ste_Nova
    1,223
    47
    lol no it doesn't!!! it cycles as needed
  28. Artimus
    Artimus Shortback
    2,016
    485
    The MY09 A3 owners manual (p71\72) states that it will cycle as & when needed to maintain the correct temperature when on Auto setting! That's the difference between Climate Control & standard Air Conditioning.
    One automatically keeps the cabin to a set temperature\humidity using various sensors & electromechnical flaps, the other requires manual operation. There is no "Econ" button in mine, but it does use more fuel in full auto mode.
  29. coxy8329
    coxy8329 Member
    167
    19
    Air con on.
    I know nothing about cars, so probably wrong, but do play with climate control systems.
    The aircon compressor engaged should only run when demanded by the electronic climate control system (eccs). The eccs controls the compressor's clutch among other things.
    Aircon cooling, vapour cycle process, dehumidifies the air, which is why it demists windows better with it switched on.
    Most vapour cycle cooling systems will have a lubricating oil in them to lubricate the compressor, expansion valves, and to keep the seals moist. If a vapour cycle system is not run regularly, the oil could pool which can lead to problems such as gas loss. When the system is re-gassed some of the oil is lost and the technician should replenish the lost oil.
  30. fangio
    1,488
    175
    Then my handbook is wrong.......
    'Nuff said.:undwech:
  31. Ash187
    7,490
    742
    because the combination of cold nights and jack frost make my windscreen icy so i needs something to clear it out
  32. fangio
    1,488
    175
    Aww, poor Ash. No garage! :(
  33. 964kevin
    964kevin Member
    107
    On mine I only use to defrost in the winter, and when needed in the summer.
    The DIS has a function showing the amount of fuel being used by the aircon, from memeory about 1/10th Gallon per hour at most settings.
    Kevin
  34. Artimus
    Artimus Shortback
    2,016
    485
    isn't that on newer models only, or is it a function that can be enabled on any 8P DIS?
  35. monopole
    monopole Well-Known Member
    1,154
    470
    Should be selectable, but I don't know what year from. I turned it off, paranoia!
  36. Ash187
    7,490
    742
    that is a feature of the newer models... from 2011 iirc.
  37. L333fow
    L333fow Member
    66
    Just to slightly hi-hack this thread, I have a 2007 sportback 2.0tdi s-line and is currently in audi body shop and the courtesy car is a 2012 standard a3
    now after reading this thread i started using auto more in my car and seemed ok but did notice it seemed like it was speed dependant I.e when you hit motorway the fan speed shot up! And if on hi it stayed on full! Then if you knocked temp down to 28 it dropped a bit but still stayed there!
    Now in the Courtesy car when set on auto it doesn't automatically shoot to full unless is cold and when it warms up on hi it knocks speed down and doesn't shoot up with speed
    ( what I see as normal operation) now my question is, is there something wrong with my climate control?
  38. Ash187
    7,490
    742
    Not sure if there is something wrong with your one, on mine if the car is cold an I put it on 28 the fan speed would go up until the inside of the car is really hot and then the fans go down for a bit but the temp in the car would drop again so it would go up and down as nessesary, but bare in mind 28 is really hot so it would take quite a bit of time for the climate unit to get that temp right in the car
    You can always get the car scanned on VCDS and see if there is a fault. There is a temp sender in the bottom of the air vents which you can get to if you remove the panels and have a look underneath... Make sure that temp sender is in place as it can get knocked out which would make the system not recognise what temp is inside the car
  39. audicruiser
    audicruiser Audi Heaven
    1,865
    Agreed, set the temp to around 20 in the summer and 22 in the winter, and you never need to touch it. With regards to the fuel used, if it's on all the time it won't make any difference. The heated rear screen uses fuel when it's on along with heated seats etc etc, but we still use them.
  40. Ben2487
    Ben2487 Active Member
    249
    111
    43
    If its not used for a long period of time isn't unhealthy for the gas and seals,
    someone told me regularly use the a/c it will last longer?
