Absolutly gutted.. Has my head gasket gone?
Lloydie22 Feb 9, 2014
  1. H17YD L
    H17YD L Active Member
    383
    76
    Looks just like mine does most of the time! I only do about 6 miles a day and after a week its like that. I have a catch can and that fills up pretty quick too. I used to be worried about it but I've changed the oil twice (in 1 year, 4k miles) had a few big journeys and it always goes back to normal pure black after a good run. Then when I use it just for getting to work and I get the mayo back.
  2. H17YD L
    383
    76
  3. Lloydie22
    Lloydie22 Member
    62
    9
    Surely there should be no mayo regardless on a lovely bit of german engineering? I've gone for a longgg drive tonight for just over an hour. Havent checked the oil yet, but the coolant hasnt lost any, no tempreture problems. I shall check when its cooled down. But its looking promising
  4. Oggy-s3
    Oggy-s3 Member
    132
    Fingers crossed Lloydie!
  5. XFi
    XFi In need of a V8.
    491
    47
    Don't expect miracles by any means, did you redline it a lot? A long drive isn't enough to burn it off unless you are pushing hard. Signs are good though with no coolant lose etc.
    German engineering is not the issue here, fuel for instance has moisture in it and it can just build up over time.
  6. Lewis583
    956
    91
    German engineering can't overcome physics though. Hot gas + cold surface = condensation.
    My 20T had a bit of mayo on the filler cap once, but then i was doing 3 miles to work in the morning (in stop/start traffic) and the same home of an evening. I took it for a blast down some lanes, so some prolonged hard use and it went away.
  7. T8DPR
    T8DPR If Carlsberg Made Audi Drivers...
    794
    140
    43
    every week take your car for a good long run, I don't do much in the way of commuter mileage but if time allows i'll go out for a good couple of hours just to give the engine what it wants, full running temp!
  8. T8DPR
    794
    140
    43
    bought from a dealer and owned for under 6 months, you're covered by the sale of goods act for 6 months from the purchase date, regardless of a garage who might even claim its sold as seen, and its not for you to prove it was faulty when you bought it, its for them to prove it wasn't, which they usually cant
    they shouldn't refuse, if they do try to, then mention the sale of goods act giving 6 months, if that fails, trading standards. if you have to put anything in writing, keep records, but most of the time it'll never come to that
  9. 37
    37 Member
    129
    This thread got me cynical about the cap. Incidentally, low engine oil light came up too. When I got home after a long run, inside of the cap was absolutely normal. However, ever since then, I've done short runs, 3 miles top and the cap is milky. However the dipstick is absolutely fine.
    I've been told (Service head at Audi Garage) this is because of condensation and everything should be fine. No unusual noises/temps/exhaust gases etc
  10. discostu49
    discostu49 Active Member
    601
    132
    43
    Am I at risk to this in my 3.2,??? I do about 2 miles to work and 2 miles from work just urban, then the odd blast down the motorway midweek and a good thrash at the weekends ? I've checked the cap seems no issues ??
  11. XFi
    491
    47
    There is no risk as such, well there is with prolonged short journeys but modern engines should not have such problems now.
  12. Keane
    Keane Active Member
    476
    66
    Mine has this too, all tested okay but no way near a bad as that.Hope you get her sorted :)
  13. H17YD L
    383
    76
    There's nothing to sort unless he gets a job 30 miles from home lol
