Abs wheel speed signal (left Rear) ???
Discussion in 'A3/S3 Forum (8L Chassis)' started by dplovin, Jul 30, 2012.
  1. dplovin
    dplovin Member
    Jan 11, 2011
    417
    got the abs light on in my prefacelift S3 and this fault code popped up 00290 p1726 which it says its ABS wheel speed signal (left Rear)
    im guessing its the sensor? or is there anything else it could be
    anyone ever had this problem before
  2. Advert Guest Advertisement
  3. calico101
    calico101 New Member
    Mar 28, 2012
    check the wiring from the sensor as well mine had worn through .Needed to replace the loom sensor was fine .
  4. dplovin
    dplovin Member
    Jan 11, 2011
    417
    Do you know if it's easy to replace
  5. calico101
    Mar 28, 2012
    My mechanic did the work . But the loom was about £32.00. It may just be something as simple as the senosr in your case . but something to bare in mind before you replace the sensor just have a quick look under the car .
  6. murran
    murran Well-Known Member
    Aug 10, 2010
    1,545
    39
    it "should" be easy to replace.
    but if the 5mm headed bolt that holds the sensor in is rusty or rounds off/snaps, it starts being not so easy.....
    the sensor itself can also get seized in if rust has got in the hole the sensor slots into. meaning you have to fight the old sensor out usually a bit at a time. then dremel the rust out of the hole to enable you to fit the new one.
    check out the wiring first as suggested. good call.
  7. dplovin
    dplovin Member
    Jan 11, 2011
    417
    Cheers guys I'll give it a go over the weekend
