Abs warning
vwgtiking Jun 21, 2014
  1. vwgtiking
    vwgtiking Active Member
    1,030
    Again got car back from body shop and now the abs light is on? Any ideas why it could be on?
  2. vwgtiking
    1,030
    It's not the abs but I looks brake related it's an orange symbol where the ok normally appears
  3. vwgtiking
    1,030
    Just done scan and nothing showed. Would knocking something if wheel was removed cause a problem? Cos the Symbol should only show if the 2 wires in pads connect?
    This lowest pad is about 3 or 4mm thick. Is this at 25%?
  4. BakPak
    BakPak No Gear
    957
    137
    43
    Connect them and see if the light goes out?
  5. vwgtiking
    1,030
    Wouldn't know how. Isn't the wires in the pad?
  6. vwgtiking
    1,030
    If the sensor was accidentally unplugged or something, would this come up? Vagcom doesn't say which pad is low or any error.
