ABS WARNING LIGHTS??
blanc Sep 18, 2011
  1. blanc
    blanc Member
    47
    Hi All
    Sometimes the abs and traction control warning lights come on on my car, it has a mind of its own when it comes on but turns back off when I turn off and back on the ignition.
    It is readingy abs fault 1 , I have replaced the brake pedal switch which did not cure the problem. The mechanic feel it is either the abs thrust switch or the abs pump. Any Ideas?
    Car is a 2003 Quattro TDI 2.5 and an auto.
  2. quattrojames
    14,050
    578
    ABS switch on the hub?
  3. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,232
    172
    Got a brake light bulb out?
  4. Dibs_h
    Dibs_h New Member
    27
  5. blanc
    blanc Member
    47
    Neither both good, yesterday when the lights came on I had to break hard and the abs did not work , the front locked up so whatever is happening when the lights come on together the abs is being turned off. Any Ideas>
  6. marktdisport
    marktdisport Active Member
    1,195
    15
    if the lights on then you have a intermittant fault probably have a dodgy wheel hub sensor, mine comes on at least once every few months usually when a bit wet like you say turn off ignition and restart and lights goes off again !!! mine is a dodgy wheel hub sensor....
    if the light's showing then the abs should be disabled.... same as the air bag light if its on they dont work
