ABS warning light
jgrand Oct 12, 2004
  1. jgrand
    jgrand Member
    147
    After starting the car the other day, the ABS and ESP warning lights stayed on. Shortly afterwards the brake pad warning came on. I know the ESP light is on because of the ABS warning and I know the pads need replacing but is the ABS problem likely to be related to the pads - i.e. will it go away when I replace the pads? Will I need VAG-COM to reset the warning or, if it is related to the pads, will it reset itself?
  2. imported_Rooney
    imported_Rooney Guest
    Could be a faulty speed sensor?
  3. jgrand
    jgrand Member
    147
    Where are the ABS sensors located? I just had a wheel bearing replaced, could the problem be related to this?
  4. peteA3tdi
    peteA3tdi Member
    408
    [ QUOTE ]
    [/ QUOTE ]
    in a word yes, take it back and get them to recheck it, was it the near side front by any chance?
  5. jgrand
    jgrand Member
    147
    Funnily enough, yes it was. Why? I'll be phoning AmD later today.
