ABS UNIT/ECU
ginna104 Jun 8, 2009
  1. ginna104
    ginna104 Member
    32
    hi i'm after a 2nd hand abs unit/ecu but the ones ive seen are a different number to the one on my car my part number is 8EO614111A but all the others iv'e looked at have another letter on the end for instance 8EO614111AM does anyone no if this unit will work on my car ?? cheers ginna
  2. dieselfitter251
    dieselfitter251 Blow ma own trumpet?
    1,120
    Hey man. Search the forums for all the related info but I'm guessing you've got quattro, probably with EDL. You need an 8E0614111A or 8E0614111E, (I think). The unit may ben repairable yourself, (again check the forum) but check out bba-reman they'll do you a fix for about £100. If it's unfixable they'll sort you out with a recon unit.
    You got any fault codes or symptons?
  3. ginna104
    ginna104 Member
    32
    hi iv'e checked the forum for related issue's as i was getting the big flashin exclamation mark and the abs light on. i found a repair for the abs ecu which i did and the wire was broken so repaired that and the big red light goes off and just flashes every now and again ive scanned with vag-com and it's sayin nsf wheel speed sensor just got to change that and re-check everything i thought the intermittant big red flash is still meaning the ecu is still dodgy !! yes iv'e got a 2.8 quattro 30v, what's edl ?? cheers for the reply dieselfitter
  4. dieselfitter251
    1,120
    Potentially still your ecu but change the sensor. It's still the cheaper option. Good luck!
  5. aragorn
    18,577
    868
    if it detects a faulty wheel sensor you'll get the big (!)
    If its an ECU fault it usually brings the (!) up as soon as you start the car.
  6. ginna104
    ginna104 Member
    32
    right well the big red (!) isn't on when starting just the abs light then sometimes the big red (!) appears for a little while then goe's..
  7. ian52
    ian52 2000 a4 1.8tqs-yellow
    1,199
    mine done this. i fixed the wire but think i broke something else. i got no (!) but the abs light was on all the time.
  8. ginna104
    ginna104 Member
    32
    ian have you scanned it with vag com ? mine has come up with nsf abs sensor fault !! gonna try it and see what happens !
  9. ian52
    1,199
    i did at the time.think it said driver side front on mine but it was the module that was shot.
  10. ginna104
    ginna104 Member
    32
    ah right ! did you buy a new one or send it to bba reman ? ?
  11. ian52
    1,199
    bought a working secondhand one.
  12. ginna104
    ginna104 Member
    32
    ok mate cheers !
