ABS Sleeve
wysiwyg Nov 1, 2012
  1. wysiwyg
    wysiwyg Member
    Mullered the sleeve removing the abs sensor, the 'new' sensor is both wrong and used, cheers gsf, but i digress.
    Does the abs sleeve have to be copper or can i wrap something else around it to hold it in place, either a piece of metal or plastic?
  2. aragorn
    18,547
    865
    i'd goto the dealer and get the proper brass insert. It acts as a sort of spring to hold it in place, while allowing enough movement to adjust it.
