Hi,
had abs and esp lights flash up on the way into work a few days ago. quick scan with VCDS gives me the following codes.
65535 - Internal Control Module Memory Error
00-00 - -
00283 - Front Left ABS Wheel Speed Sensor (G47)
35-10 - - - Intermittent
16-10 - Signal Outside Specifications - Intermittent
01130 - ABS Operation
27-10 - Implausible Signal - Intermittent
i cleaned up the abs sensor and cleared the codes. The lights came back on about an hour later but this time only this code is showing.
do you think its just the Sensor or the module?
00-00 - -
