ABS Reluctor Ring (rear)
tonybolony Sep 13, 2012
  1. tonybolony
    tonybolony Member
    138
    Just wanting to know if this is in the Hub assembly or the CV on the rear of the Car , i want to see if its got a crack in it or corroded as i am having activation coming from the rear.
    thanks in advance
  2. PAULF
    PAULF Active Member VCDS Map User
    712
    66
    On the Quattro, it's on the CV joint.
    The ring is a shrink fit, so you need to get it cherry red before you plop it on (get it the correct way around!!)
    If you go here How to replace front and rear suspension parts (with pics) there is a pic further down of a broken one on the joint, plus how I repaired mine!
  3. tonybolony
    tonybolony Member
    138
    thankyou for the Reply mate
