ABS Problem - Can You Get Replacement ABS Rings on their own?
Springer* Jul 26, 2013
  1. Springer*
    Springer* Member
    168
    17
    Hi there,
    My car has recently developed an issue with the ABS which is due to corrosion of the ABS rings due to age/wear and tear..
    Does anyone know if the ABS rings themselves (the toothed rings that are on the end of the drive shafts at the front) can be purchased on their own or do they only come as part of the hub or drive shaft assembly?
    Obviously I would imagine that if they only come as part of the drive shaft etc it would be considerably more expensive.
    Any info would be much appreciated.
    J:)
  2. glenandem
    glenandem Active Member
    674
    31
    hi, not sure if you can get them separate for the audi's but ive fitted them to other makes of cars.
    couldnt you get the cv joint instead of a full driveshaft?
    one final thing, im not sure how corroded your joint is but in the past ive just got a wirebrush and managed to clean the grooves on the abs ring!
    have you put a multimeter on it and made sure its the ring not giving the right signals?
  3. spartacus 68
    spartacus 68 Active Member quattro Audi A2 Audi Avant Owner Group
    366
    54
    It's called a reluctor ring. If the ABS is kicking in, my money is on one of the rear rings splitting. These are expensive - personally I'd go for the Ebay ones. Cheap enough to replace every few years.
    ABS Reluctor Rings - Audi cars
