abs module problem
ian52 Oct 25, 2008
  1. ian52
    ian52 2000 a4 1.8tqs-yellow
    1,199
    when the abs module goes funny is it the module under the rear seat or the abs pump under the bonnet?
  2. dieselfitter251
    dieselfitter251 Blow ma own trumpet?
    1,120
    If you've got a non-quattro car then it'll be the module under rear seat. Got a vagcom? Check for codes, it is possible that the pump could have failed but unlikely.
  3. ian52
    1,199
    its a facelift quattro sport.the light comes on for a bit then goes out for a bit.had it on a diagnostic thing and it couldnt communicate with the abs or something.
  4. dieselfitter251
    1,120
    If it's a quattro then the module will be attached to the pump in the engine bay. I don't think you should have anything relating to the ABS under the rear seat? I may be wrong as I have a pre facelift quattro sport. Are you getting an error code at all?
  5. ian52
    1,199
    i couldnt communicate or something and from what others have said thats what happens when its the module.
  6. Broken Byzan
    13,237
    465
    I am sure my control module is at my ABS pump on my 2wd 98. As i connected the wires there when i put the traction control on
  7. Nige P
    Nige P Member
    65
    the module will be bolted to the pump, it's the yaw sensor under the rear seat.
