Abs module problem
Andrei1987
Hello. If a a nad abs module, I have esp and brake lights on. I did a scanner and recognized the abs module, but didn t work. How do I know if the module is bad or needs the correct coding. In vagcom I can open the abs module controler. Anyone knows this problem?
  1. Anyone knows if is a bad abs module, or a good abs module with a bad coding
Please help me, because the nearest audi service is at 350 km away
I have a check coding of ecu, sterring whells sensor fault, airbag module, all the in abs module contreller, I can acces the module, hiw do y know if I have a bad abs module or a abs module that need s coding, seems that someone already do some work on the abs module, as it shows sign of relesen screws
What are the fault codes???
Without these nobody can help.
579
611
7K
