  1. abdul h ghafoor
    abdul h ghafoor Member
    52
    Got in car today and abs light is on permanently. I switch ignition of and wait and light still on permanently. My car is an a6 2.5 tdi Quattro auto. Any suggestions?
  2. marty.h
    marty.h Member
    124
    you will have to get the car plugged in on vag com or something like that to retrieve the fault codes once you have them you will have something to go by.
    Make sure once you have jotted the codes down clear them and see what if any returns strait away or you will be chassing your tail if you have loads of stored codes
  3. boost-addict
    boost-addict Well-Known Member
    1,000
    39
    is there 3 bleeps after igntion is switched on?
    possibly a wheel sensor. but vcds is best way to be sure.
  4. abdul h ghafoor
    52
    Well I decided to check the abs wheel sensors. The front o/s looks ,worn, and is,also cracked. Sourced one from eBay for 13 quid when it arrives a comp next week. Will update.will fit. Also is getting hooked to
  5. DONNYDARKO
    DONNYDARKO New Member
    The ABS sensors can be tested with a multimeter. Set the meter to millivolts ,connect both leads to the pins in the connector and turn the wheel. a good sensor should read a voltage as the wheel turns past it.
  6. murran
    murran Well-Known Member
    1,545
    39
    youd need an osiliscope to do this check that way.
    just get the car scanned for faults. then you can pin point where the fault is.
    you can buy vag com, or go on the vag com section of the forum and see which member is nearest you that has it, pm him offering beer money to help you. if its a sensor fault, he can also check the sensor signals via actual values as your driving.
  7. Dalton
    Dalton New Member
    It needs to be plugged into a scanner/code reader to know exactly what part triggered the problem.
    ____________________
    vcm ids software
  8. fishyfish
    fishyfish Member
    126
    40
    If the sensor turns out to be ok, might be an idea to get the car up on a hoist and check if any wheels have been buckled from a pothole/kerb impact... although you would probably feel nasty vibrations etc as you drove along if it was an obvious physical failure like that.
  9. marty.h
    marty.h Member
    124
    A buckled wheel would not cause the ABS light to come on as the ABS ring will be on the shaft and for that to move it would have to do the wheel bearing and you would hear that had gone if it was bad enough to trip the ABS
  10. TwistedMind
    TwistedMind Long Live The A6
    115
    Make sure the ABS sensor is located right, if its sitting in the wrong position it will cause a fault (had this problem before)
  11. fishyfish
    fishyfish Member
    126
    40
    Fairy nuff. Just throwing it out there as I vaguely remember hearing of an instance (admittedly not an A6) where a couple of buckled wheels were enough to confuse the ABS sensors... but you are right in that if it was mechanical, it would have to be severe enough to feel/hear something.
    As you were!
  12. abdul h ghafoor
    52
    Thanks for all the advice. Waiting for. Vag com check first then will update
  13. boost-addict
    1,000
    39
    have you tried just removing the sensor, make sure theres no crud on the ring or sensor and then checking with a multimeter
  14. abdul h ghafoor
    52
    Got it hooked up to a vag comp and low and behold the abs sensor front passenger side. Replaced and hey Ho abs light gone.
  15. boost-addict
    1,000
    39
    Well not a bad fix. Was your car bleeping 3 times or just the light?
  16. abdul h ghafoor
    52
    No bleeping just the abs light was on so fell lucky I suppose that abs unit a ok.
