ABS light. what light??
wsdizzys3 Apr 28, 2014
  1. wsdizzys3
    wsdizzys3 New Member
    17
    Basically when I turn my ignition on I dont get my abs light come on. I have run a scan with vcds and p1851 came up and 2 front abs sensor's. I originally thought my master cylinder had gone but upon further inspection someone had filled the brake fluid up with what looked like atf fluid. So I went to run a abs pump bleed and it worked evan though that error code came up. I checked all fuses and there all fine but the light still doesn't illuminate evan under a instrument cluster test through vag com. Are these abs bulbs prone to failure? ?
  2. benashley
    benashley Member
    59
    Bulb may have been removed because of the faults?
    Instrument panel is easy enough to remove to check the bulb
  3. wsdizzys3
    17
    Checked inside the cluster looks like its a neon/led fixed to the board. There was 3 removable bulbs 2 missing but could see they wasnt abs anyway.
  4. Lewis583
    956
    91
    Some unscrupulous person may have done the old electrical tape on the inside of the cluster trick to mask the light being on.
    You will probably find that they haven't put ATF fluid in, the brake fluid just hasn't been changed in ages and has gone dirty.
    Clear the faults, drive the car and rescan to see what returns.
  5. wsdizzys3
    17
    I did think that aswell but ive have to cluster in bits and couldnt see nothing. I tried another set of clocks we had of another a3 lights came on but obviously wouldnt start the car and because the part numbers were different I dont think I can code them in. Can someone with a 98 a3 1.8 sport please tell me if ther ABS buls is removable or is it part of the circuit board ??
  6. JimS3
    JimS3 Active Member
    736
    72
    Its a surface mount LED, need to be confident with a fine tip soldering iron to change it.
    They don't usually fail, I suspect some one has sabotaged it with electrical tape as above or deliberately damaged the track on the PCB.
  7. myke
    myke Member VCDS Map User
    97
    is this the UKNSI part?
  8. wsdizzys3
    17
    Not sure lol how do you find that out. Looks like im gonna be getting new clocks or buying a fine tip soldering iron. Does the part numbers have to match or can I use a 140mph clock instead of a 160mph clock. It plugs in pits in and lights up ok just not sure if im codimg it right or if its just not allowing me to code it because its the wrong part code
  9. leegsi
    leegsi Active Member
    489
    57
    Shine a torch where the led would shine as you can put tape between the speedo mat and the clocks itself.
    Also try putting the clocks back in so you can see the bulb illuminate and if it doesnt push on the led to see if there is a dry joint
  10. wsdizzys3
    17
    Tried it mate had the clocks apart. Done a instrument panel test on vcds nothink. Might just have to get new clocks
  11. leegsi
    489
    57
    Are you near Portsmouth as I could solder a new led in if its that.
  12. wsdizzys3
    17
    Im in walsall mate. How much do you charge?
  13. leegsi
    489
    57
    If you were local and had the dash out with new led nothing.
    westcoast a3 likes this.
