ABS light switch off diagnostics / in south yorkshire?
jakeriddler Oct 27, 2007
  1. jakeriddler
    jakeriddler New Member
    23
    I had the pads changed recently on my A4 (98' tdi) & the sensor was knocked, the abs works so its no fault but the light in the dash is on - this needs turning off but Im told by Mototek in Doncaster it will be £45+ to turn off.
    It is only a small light, it bothers me that it need not be on but £45 for turning it off seems steep - has anyone any ideas or recomendations for a solution please?
    Maybe a cheaper diagnostic station?..
    Many thanks in advance :icon_thumright:
  2. andybnwc
    andybnwc Member
    752
    Try removing cleaning and pushing back it , ecu should check on startup then should go out , if it still comes on then there is a problem still
  3. NineNails
    NineNails Proud sponsor of the snack food industry
    593
    As above. If the abs light is still on, then there is still a related problem. Also if the abs warning is lit, you will NOT have abs, the system is disabled.
    HTH
    Si.
  4. andybnwc
    andybnwc Member
    752
    Ive had the same problem and tbh locking up at high speed in the wet aint fun ......well kind of if you dont crash lol
