ABS light on after pad and disc change?
Bigman Jan 28, 2008
  1. Bigman
    Bigman Cornish and Proud!
    85
    Right, i changed the pads and discs on my A4 yesterday and when starting the car the abs light seems to be on, i am not sure what could have caused this?
    Is it going to have to be a VAG.com search for error codes? If so if i went to an audi garage would i expect to have to pay for them to plug in and search?
    Adam
  2. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    probably a bit if ***** on the sensor unless you have knocked it off or broken a wire!
    you will have to pay unless you know someone with a system.
  3. Bigman
    85
    Problem solved, gunna get to work sorting it this afternoon...
    Adam
