abs light and esp light keeps coming on help please
madmark Dec 4, 2010
  1. madmark
    madmark Member
    173
    hello i got a a3 tdi sport x reg my abs and esp light keeps coming on and staying on anyone know what could cause this thanx mark
  2. AudiS3-Turbo
    AudiS3-Turbo Member
    619
    27
    there are a few sensors lateral, longitudinal ,yaw sensors,abs sensors or rings themselves so its best to have it plugged in and scanned for the fault code mate.
  3. madmark
    madmark Member
    173
    ok will look in to doing that thank you for help
  4. Jacko4130
    Jacko4130 Goodie Gum Drops
    848
    ABS light as well as ESP light can mean the ABS module has failed like whats happened to me, At least £350 to get it rebuilt or over 1k for a new unit if it is the ABS module, Get it scanned to find out ASAP.
  5. alijames
    alijames Active Member
    1,024
    My S3 started doing this about 2 months ago. By checking with vag-com, it turned out to be a dicky ABS sensor. ~£15 from your local motor factors, easy to fit the new one, but getting the old one out can be a bitch. I ended up having to use a hammer and chisel on mine!!!
    Cheers,
