ABS jibbing out....with New VAG-COM readings
ALPINE May 8, 2010
  1. ALPINE
    3,093
    just to clarify, the other day my ABS light stayed on and just went off again. We just popped to morrisons and on the way out i wheel spinned. (coz its raining and im a loon!) braked for the next turniong and i felt the ABS working in the pedal. it then was locking on and off the 200 yards i traveled before i pulled over and turned the car off and on again. The abs stopped kicking in but my lights back on.
    This is the speed sensors causing this right? these codes were chucked up
    17978- Engine start Blocked by Immobilizer
    P1570 - 35-10 --- Intermittent
    18259 - Powertrain Data Bus: Missing Message from ABS Controler
    P1851 - 35-10 --- Intermittent
  2. Prawn
    11,536
    3,481
    that doesn't look like a wheel speed sensor issue mate, they usually throw a code specific to the sensor at fault, and clearly say ''rear right wheel speed sensor - signal intermittent'' or something similar....
  3. ALPINE
    3,093
    ECU and ABS not communicating then? this is going to be expensive isnt it.
  4. ALPINE
    3,093
    just got these come up.... i didnt know i could log into just the ABS dooby...
    VAG-COM Version: Release 311.2-N
    Control Module Part Number: 1J0 907 379 E
    Component and/or Version: ABS/EDS 20 IE CAN 0001
    Software Coding: 13504
    Work Shop Code: WSC 06325
    2 Faults Found:
    00283 - Front Left ABS Wheel Speed Sensor (G47)
    35-10 - - - Intermittent
    01312 - Powertrain Data Bus
    37-10 - Faulty - Intermittent
    Control Module Part Number: 06A 906 018 AQ
    Component and/or Version: 1.8L R4/5VT MOTR HS D03
    Software Coding: 04000
    1 Fault Found:
    17978 - Engine Start Blocked by Immobilizer
    P1570 - 35-10 - - - Intermittent
    as u said prawn its there clear as day! this expensive to fix people? should i do all sensors or just the 1?
  5. finesse
    finesse Active Member
    2,805
    JOB DONE!
  6. finesse
    2,805
    Dead/dying keyfob battery?
  7. ALPINE
    3,093
    pass... im hoping to get that mapped out when i go visit Mr R_tech anyway! it always does its little "im not gonna start" trick in the fooking petrol station too! lol think it is the key tho.
  8. Broken Byzan
    13,237
    465
    It's the reader coil under the cowling casuing it not to start. The powertrain one is common, i have it and mine still works perfectly. Its that Front sensor one my money is on.
