ABS fault help please
renton Dec 13, 2012
  1. renton
    renton Member
    64
    As title had to brack hard yesterday now have a abs light on now.
    Is it the pump or the ecu that is at fault
  2. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    126
    [h=3]1276 - ABS Hydraulic Pump (V64): Signal Outside Specifications[/h][h=4]Possible Symptoms[/h]
    • Malfunction Indicator Light (MIL) ON
    [h=4]Possible Causes[/h]
    • ABS Hydraulic Pump (V64) Connector to Control Module faulty
    • Wiring and/or Connector(s) faulty
    • ABS Hydraulic Pump (V64) faulty
    • Brake Electronics Control Module (J104) faulty
    [h=4]Possible Solutions[/h]
    • Check ABS Hydraulic Pump (V64) Connector to Control Module
    • Check Wiring and/or Connector(s)
    • Check/Replace ABS Hydraulic Pump (V64)
    • Check/Replace Brake Electronics Control Module (J104)
