ABS Fault can anyone help
DenCar Mar 17, 2011
  1. DenCar
    DenCar Member
    404
    Dash lights come on, ABS and Traction, I ran VCDS and got the following codes:
    2 Faults Found:
    00283 - ABS Wheel Speed Sensor; Front Left (G47)
    003 - Mechanical Failure - Intermittent
    012 - Electrical Fault in Circuit
    Does anyone know the likely cause.
    DC
  2. Sandip
    2,438
    91
    Remove the wheel, behind the disc there's a sensor which reads wheel speed off pulse/magnetism, check the connection is ok first, it's more than likely that there's some dirt between the sensor and the abs ring (metal bit with holes in it), spray some brake cleaner inbetween the sensor and abs ring to clean the face of the sensor
    Clear the faults go for a drive and see if it comes back on, if it does then it could be the sensor that needs replacing
  3. DenCar
    DenCar Member
    404
    Thanks again sandip, I will have a look as soon as i can, I had collies fitted last saturday so maybe some **** has fallen from the arches as they took off the old stuff.
    DC
