Evening Chaps!
Still got my ABS fault and wondered if anyone could please help me.....
Had the car code read and the faults being brought up are:
01316 - ABS Control Module No Signal/Communication
00778 - Steering Angle Sensor (G85) No Plausible Signal
3803 - Steering Angle Sensor for Steering Aid
I've been told the steering angle sensor fault is as a result of the ABS fault. So I need to fix the ABS fault first.
Looking on Ross Tech it says the following:
01316 - ABS Control Module 01316 - ABS Control Module: No Signal/Communication Possible Causes
So it seems I need to look at the wiring connector onto the ABS pump?
If anyone has experienced this fault or can help me at all it would be much appreciated
Thanks all,
Christian
- Wiring/Connector(s) from/to ABS Control Module faulty
- Fault(s) stored in ABS Control Module
- Check Wiring/Connector(s) from/to ABS Control Module
- Check Measuring Value Blocks (MVB)
- Usually Measuring Value Blocks (MVB) 125+ show the current Communication Status
Thanks all,
Christian
