ABS/ESP fault scan inside help needed.
Cozza McA Nov 11, 2013
  1. Cozza McA
    Cozza McA Crunching The Gears VCDS Map User
    410
    72
    HI after some help with this scan
    1. the ESP fault, is it a big issue
    2. the heated seat 'problem' seat still gets hot so don't know what the problem really is
    any help would be good thanks
    Corey
    VCDS Version: Release 12.12.0 (x64)
    Data version: 20130910
    Monday,11,November,2013,16:48:11:18744
    Chassis Type: 8P (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56
    VIN: WAUZZZ8P97A223304 Mileage: 107110km/66555miles
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    Address 01: Engine Labels: 03C-906-056-BAG.lbl
    Part No SW: 03C 906 056 ED HW: Hardware No
    Component: MED9.5.10 G00 0236
    Revision: 66H09--- Serial number: AUX7Z0G4FN70D3
    Coding: 0000072
    Shop #: WSC 06314 000 00000
    VCID: 69DFF8934030DA5623D-803C
    No fault code found.
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
    Component: ESP FRONT MK60 0101
    Revision: 00H11001
    Coding: 0019074
    VCID: 73E39AFB12FC1086991-8026
    1 Fault Found:
    00290 - ABS Wheel Speed Sensor; Rear Left (G46)
    003 - Mechanical Failure - Intermittent
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 AD HW: 8P0 820 043 AD
    Component: KlimavollautomatH19 0360
    Revision: 078503 Serial number: 8P0820043AD
    Shop #: WSC 00000 000 00000
    VCID: 6ED58B8F79DE3D6E76F-803B
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
    Component: Bordnetz-SG H43 1201
    Revision: 00H43000 Serial number: 00000007067309
    Coding: A58CCF27A014100000000000000000000009FE175C0100
    Shop #: WSC 06314 123 08192
    VCID: 4089053713CAFB1ED43-8015
    Subsystem 1 - Part No: 8P2 955 119 E Labels: 1KX-955-119.CLB
    Component: Wischer AU350 H01 0130
    Coding: 00062736
    Shop #: WSC 06314
    1 Fault Found:
    02092 - Enabling Heated Seat
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 234
    Mileage: 106952 km
    Time Indication: 0
    Date: 2013.11.09
    Time: 16:16:00
    Freeze Frame:
    ON
    Voltage: 14.00 V
    ON
    ON
    OFF
    OFF
    OFF
    Address 15: Airbags Labels: 8P0-959-655-94.lbl
    Part No SW: 8P0 959 655 H HW: 8P0 959 655 H
    Component: Airbag 9.41 H13 4220
    Revision: 91H13422 Serial number: 0037W0G1J8LL
    Coding: 0071612
    VCID: 479B1E2B36E4CC26159-8012
    Subsystem 1 - Serial number: 63328RB4026F4BC3V
    Subsystem 2 - Serial number: 63428RB402698CFD1
    Subsystem 3 - Serial number: 63528RB4026F4BCE1
    Subsystem 4 - Serial number: 63628RB402698D2F-
    Subsystem 5 - Serial number: 63729RB402667631E
    Subsystem 6 - Serial number: 63829RB4026676B7T
    Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
    Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
    Component: J0527 H36 0070
    Coding: 0002042
    VCID: 418F003318C0F216DBD-8014
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: E0221 H02 0100
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 981 G HW: 8P0 920 981 G
    Component: KOMBIINSTR. VDO H20 0570
    Revision: D0H20004 Serial number: 2244G004006249
    Coding: 0004418
    Shop #: WSC 06529 000 1048576
    VCID: 3C7171C77F229FFE88B-8069
    Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
    Part No SW: 1K0 907 530 K HW: 1K0 907 951
    Component: J533__Gateway H12 0170
    Revision: H12 Serial number: 330010742003FC
    Coding: 3D0F034207000101
    Shop #: WSC 06314 123 12345
    VCID: 2F6B568BBE5474663D9-807A
    1 Fault Found:
    02649 - Digital Radio Tuner
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 154
    Mileage: 104665 km
    Time Indication: 0
    Date: 2013.10.10
    Time: 18:55:40
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D0H20004 Serial number: AUX7Z0G4FN70D3
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN2.lbl
    Part No: 8P0 959 801 H
    Component: Tuer-SG 020 0090
    Coding: 0000624
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K2 909 144 L
    Component: EPS_ZFLS Kl.078 H07 1806
    Shop #: WSC 02069 000 90108
    VCID: 356764E35C084EB6775-8060
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 F
    Component: KSG H05 0070
    Coding: 9880202002586D298505489AC637
    VCID: 3F8B06CB6E3484E6AD9-806A
    Subsystem 1 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Subsystem 2 - Part No: 1K0 907 719 C
    Component: Neigungssensor 005 0003
    Subsystem 3 - Part No: 8P0 951 177
    Component: Innenraumueberw.H04 0020
    1 Fault Found:
    00352 - Terminal 30A
    011 - Open Circuit
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P3 035 382 HW: 8P3 035 382
    Component: AB2 SUBWOOFERBOXH27 0160
    Revision: 00005 Serial number: 30659635803312
    VCID: F0E915F7E3EAAB9EE43-80A5
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
    Part No: 8P0 959 802 H
    Coding: 0000624
    Address 56: Radio Labels: 8J0-035-1xx-56.clb
    Part No SW: 8P0 035 195 G HW: 8P0 035 195 G
    Component: R Symphony2+ H15 0240
    Revision: 00H15000 Serial number: AUZ1Z4G9063813
    Coding: 0010111
    VCID: 366563EF410E45AE7EF-8063
    1 Fault Found:
    00821 - Antenna 2 for Radio (R93)
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 21
    Reset counter: 228
    Mileage: 104665 km
    Time Indication: 0
    Date: 2013.10.10
    Time: 19:01:42
    End ---------------------------------------------------------------------
  2. NHN
    29,280
    1,692
    I would say someone's been playing with coding :)
    Just decode the heated seats from 09, remove digital radio from gateway 19, try to clear antenna fault from radio 56 & clean the rear abs sensor/connector, if still comes back then replace.
  3. Cozza McA
    410
    72
    Only a little bit haha.
    Decode?? Checky I do have heated seats honest.
    ok will do that for the digital radio, the other antenna 2 fault is because I have the AutoDab installed.
    will do that with the ABS. Ill let u know how I get on.
    cheers
  4. NHN
    29,280
    1,692
    Yeah on 8p, module 09 usually has nothing to do with heated seats, so disable it & see if it goes away & seats still work :)
