ABS/ESP Fault MOT Failure
markh07 Jun 12, 2014
  1. markh07
    markh07 New Member
    10
    Hi people hope you guys can help out my car failed its MOT on Tuesday because the ESP light is on the dash, i wasn't too worried about it before but looks like ive got to get it sorted for the MOT. i dont really want to have to paty for a restest so if i can get it sorted within the 10 days would be great. I had it plugged into VAG a while ago it showed fault Break Pressure Sensor 1 (G201) fault code 01435. Now i understand its a new ABS pump that is needed what are my options basically? Can i change it myself then take it to get it plugged in to program it through VAG or will i not be able to drive it untill its programmed? or Can i just take the ABS ECU off the pump and send it off to ecutesting.com for repair or is it the pump that needs repairing? any help would be appreciated Thanks Mark
  2. mjr901
    mjr901 Guest Gold Supporter Audi S3
    3,595
    1,063
    There is a repair kit available from the main dealers.
    1K0 698 517 B
  3. markh07
    markh07 New Member
    10
    Ah ok cool is this a repair i could do or does it have to go to them to have it done? any idea how much these repair kits cost?
  4. mjr901
    3,595
    1,063
    If i was sat back at work I could tell you how many were sat on the shelf at every VAG dealer in the country!
    I'll punch it in tomorrow if you want and give you an idea of price.
  5. mjr901
    3,595
    1,063
    01435 - Ross-Tech Wiki
    Cover cheaper aspects before using the repair kit. Probably have to do some sort of basic setting once installed, but I'm not 100%.
    Ie check your brake switch isn't jammed etc
  6. markh07
    markh07 New Member
    10
    Yeh ok if you could that would be Great is it something that can be fitted by myself or would it be a main dealer job? Many Thanks
  7. mjr901
    3,595
    1,063
    I don't physically fit the parts. I sell them! So I'm not sure.
    I'd be inclined to take it to a VAG independent. What's your location so you can be directed appropriately.
  8. NHN
    29,327
    1,708
    Yeap as above, repair kit needed.
  9. LEE69
    LEE69 07 170 DSG Team Dolphin Grey Audi A3
    2,193
    385
  10. veeeight
    veeeight I am a very pretty girl VCDS Map User Black Edition
    6,849
    4,758
  11. markh07
    markh07 New Member
    10
    Sorry for late reply I'm in Somerset I've just rang an Audi specialist for a price but if I can I'd rather try and do the repair kit myself
  12. mjr901
    3,595
    1,063
    veeeight likes this.
