ABS Discovery
Pubemammal Jul 28, 2013
  1. Pubemammal
    Pubemammal Active Member
    528
    117
    43
    My ABS light has been randomly coming on and off for a few days, sometimes ABS will kick in at around 5mph and judder and vibrate through the pedal. It once did this when braking from 40mph which badly affected braking performance, I had to release pedal and reapply the brake for it to function properly.
    I had a quick peek today and found this.... Surely that's not right? Shouldn't there be a 2 pin plug going into the female plug and not just wires (which are split).
  2. superkarl
    superkarl MAN OF STEEL
    9,610
    2,481
    yep usually a plug, think they can be bought from audi
  3. Pubemammal
    528
    117
    43
    Thanks.. Would the plug need to be soldered on, there is spade type connectors on the end of the wires at the moment :/
  4. hades-
    9,482
    646
    no you can repin a new plug
    but looks like the wires are broke so you will need repair wires aswell or that part of the loom if they sell it
  5. Pubemammal
    528
    117
    43
    Thanks for reply. What a PITA. Maybe there is enough slack wire to cut them where they've broken and put the plug on there? Can anybody get me a part number for the plug I need (male) please?
    Sam
  6. hades-
    9,482
    646
    you get repair wires with the plug
    snip off and solder new ones on quite an easy job
  7. Pubemammal
    528
    117
    43
    Sounds good to me buddy. Just got to find the plug now! Thanks for your help.
  8. hades-
    9,482
    646
    go into audi they will sort you
    or someone will be along with a part number
  9. Pubemammal
    528
    117
    43
    Looks like I'm going to have too. Can't find it ANYWHERE online!
  10. Pubemammal
    528
    117
    43
