ABS control Units
Discussion in 'A6/S6/Allroad forum (C5 Chassis)' started by meatychi, Oct 10, 2008.
  1. meatychi
    meatychi Member
    Jan 1, 2005
    261
    My motor has just had it's MOT and I have been told that my ABS control unit needs replacing.
    According to my garage they say that it is a common fault with the A6 2.5tdi's
    Is this true, it seems that all faults are common faults?
    Can anyone tell me how much you would expect to pay for replacing said control unit?
  2. Advert Guest Advertisement
  3. Flying Spanner
    Oct 11, 2008
    30
    I would need part number, but for and ABS Unit with electronic control unit 4D0 614 111 J on a 98 A6 is £1259.2
    A repair set would be £465.49 for 8E0 998 375 C which is just the ECU
    THESE ARE GUIDES ONLY YOU NEED THE PART NUMBERS FROM YOUR CAR FOR CORRECT PRICE
  4. meatychi
    meatychi Member
    Jan 1, 2005
    261
    Thanks however I will be sending it to BBA remen and getting it re-engineered 8E0 614 111A for £100 +shipping
  5. Flying Spanner
    Oct 11, 2008
    30
    Nice one. You could repair the unit yourself if your handy with a soldering iron.
  6. meatychi
    meatychi Member
    Jan 1, 2005
    261
    Well I got my ECU back, fitted it and hey presto no ABS light and no fault codes!
    All for £145
    Loads better than the £700 I was quoted!
  7. enda1
    enda1 Member
    Jan 17, 2006
    436
    I've got a 99 A6 1.8t. Over the last couple of weeks the ABS light and the big red brake warning light on the DIS have been coming on intermittently but are staying on for londer and longer.
    I ran a vagcom scan and this is what I got
    Address 03: ABS Brakes Labels: 8E0-614-111-EDS.LBL
    Part No: 8E0 614 111 B
    Component: ABS/EDS 5.3 FRONT D10
    1 Fault Found:
    01203 - Electrical Connection between ABS and Instrument Cluster
    03-10 - No Signal - Intermittent
    I checked the output from the wheel sensors and they are all measuring the same speed so I'm assuming they are fine.
    I ran the output test on the ABS system and everything aperaed fine in that the ABS pump cycled and I could feel the pedal pulsing as each wheel valve was tested.
    On Ross-Tech Wiki I got the following
    01203 - Electrical Connection between ABS and Instrument Cluster: No Signal
    Possible Symptoms
    ABS Malfunctions
    Possible Causes
    Wiring between ABS and Instrument Cluster defective
    ABS incorrectly coded
    Instrument Cluster defective (rare)
    Possible Solutions
    Check Wiring between ABS and Instrument Cluster for Short to Plus
    Check ABS Coding
    Check Instrument Cluster
    Can anyone point me in the direction of:
    1) where the defective wiring (if that) could be
    2) Is there a way to test my instrument cluster to see if this is the problem
    3) Is there a way to test the ABS ECU befroe spending money on getting it fixed.
  8. meatychi
    meatychi Member
    Jan 1, 2005
    261
    Not sure if you read the other post but here are the fault codes that I cleared after repairing the ECU:
    Controller: 8E0 614 111 A
    Component: ABS/EDS 5.3 QUATTRO D00
    Coding: 0273004284
    Shop #: BB 24334
    3 Faults Found:
    31-10 - Open or Short to Ground - Intermittent
    00526 - Brake Light Switch-F
    36-10 - Open Circuit - Intermittent
    Your results look familiar!
  9. enda1
    enda1 Member
    Jan 17, 2006
    436
    Thanks for the reply
    I Read the other post. Just wondering if the code below was what you got befroe you got it repaired.
  10. meatychi
    meatychi Member
    Jan 1, 2005
    261
    Before the ECU was re-engineered it wasn't possible to scan the ABS controller using both a the Bosch and theVAG-Com tools.
    The codes I listed above are the fault codes that were there before the repair took place.
    I have driven the car for a week now and after rescanning, there is no evidence of the fault codes re-occurring.
  11. Flying Spanner
    Oct 11, 2008
    30
    Lost comms will be a fault within the ABS ECU. Open it up and solder a jump wire where the tiny link from pin to board has broken. If you don't want to do this either buy a new one or send it for repair.
    The brake circuit F on someones log means the contact for pins 2 and 3 in the switch are open circuit sporadic, you may also have brake lights stuck on all the time due to a fracture by the tiny rivets which causes the tension in the switch to fail. You could also get this fault if both brake bulbs have blown (more so on A4) but centre high level light works. It will log a fault and flash glow lamp if its a diesel. These switches are rubbish but they have finally changed the design to one which wont fail, so get yours changed if its pre 4F.
  12. enda1
    enda1 Member
    Jan 17, 2006
    436
    Sent the ABS module to BBA-reman and got it back on friday. Fitted it on Saturday and scanned with VAgcom. All problems solved. Very impressed with BBA-remans service and a good price
  13. maxlbrown
    maxlbrown Deep Blue
    Jan 26, 2006
    248
    NOte
    If you can read the fault codes with the ECU still plugged iin the problem is not the standard power issue which is known.
    If you cant read the Fault codes then the it is certainly the known fault in which the power circuit fries inside the ECU.
    M
  14. ptr2279
    ptr2279 New Member
    Jan 28, 2009
    Dealership says they are able to communicatte with the module as far as coding, but when you start the car it resets back. They said it is the abs module. They also replaced the turn signal stalk.
