ABS coming in at low speeds...
S4_dan Mar 22, 2012
  1. S4_dan
    S4_dan Fire up the Quattro! VCDS Map User
    2,702
    158
    Hi all,
    I've got the common 'ABS coming in at low speeds as i'm about to stop'
    VCDS hasn't picked up any DTC's as in no sensor failure.
    But is there a way VCDS can detect which sensor it is that is activating the ABS?
    Doing front suspension next week, so could change the reluctor rings then if its the front ones that are causing the problems.
    Cheers,
    Dan
  2. aragorn
    18,139
    765
    Usually its a broken ring, or a not-quite-fitted-properly ABS sensor.
    Ive seen a few rear rings break, but no fronts yet.
  3. NineNails
    NineNails Proud sponsor of the snack food industry
    591
  4. S4_dan
    2,702
    158
    Works fine on my laptop. Cheers for that. will run some tests over the weekend.
