ABS Brakes fault
DeckedS3 Jan 20, 2009
  1. DeckedS3
    DeckedS3 Well-Known Member
    863
    292
    Hello,
    I've just done a scan and as the scan started, up on the dash it said ABS fault, drive to dealer carefully..... I though it was a bit odd so as the scan went on, sure enough it's popped up with an ABS fault.
    1 Fault Found:
    01314 - Engine Control Module
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 156
    Mileage: 2700 km
    Time Indication: 0
    Date: 2008.12.29
    Time: 14:10:53
    Freeze Frame:
    Count: 0
    Count: 0
    Count: 12800
    Count: 8194
    Count: 43264
    Count: 0
    Count: 0
    Count: 0
    I took the car out and tested the ABS and it's working fine..... So I cleared the code.
    I then did another scan and straight away it popped up on the dash ABS fault, drive to dealer carefully but this time no fault code.......
    Is it normal for this to pop up when doing a scan? I have run the scan a few times now and the same thing happens but no code.
    The ABS fault was some time ago so it wasn't recent....... Bit weird if you ask me.
    Can anyone shed some light on this?
    EDIT: There was also this......
    Cent. Elect
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 156
    Mileage: 2700 km
    Time Indication: 0
    Date: 2008.12.29
    Time: 14:10:00
    Freeze Frame:
    ON
    Voltage: 11.90 V
    OFF
    ON
    OFF
    OFF
    OFF
    CAN Gateway
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 156
    Mileage: 2700 km
    Time Indication: 0
    Date: 2008.12.29
    Time: 14:10:54
  2. thorsy22
    thorsy22 Member
    308
    When scanning I believe it turns the ABS controller off so you get the error. Not sure if it logs a fault code though.
    Though may be wrong
