ABS and Tracion control light on all the time.
myke Jul 6, 2010
  1. myke
    myke Member VCDS Map User
    95
    I have the ABS light and traction control light on all the time now, but my brake lights are working ...
    Can anyone help ?
    Traction control is turned off and ABS is switched off too...
  2. AudiS3-Turbo
    AudiS3-Turbo Member
    619
    27
    You will nedd to have it pluged into vagcom (vcds) to scan for fault codes and go from there mate regardless of your brake lights working bud.
  3. Chlippo
    Chlippo Member
    679
    15
    speed sensors...yaw sensor...acceleration sensor
  4. AndyMac
    9,832
    46
    You can switch off ABS?
  5. AudiS3-Turbo
    AudiS3-Turbo Member
    619
    27
    I think what he meant was with the abs/esp light on the abs/esp is not working....dont guess,put diagnostics on there to find out the fault as one will be logged.
  6. Chlippo
    Chlippo Member
    679
    15
    for sure you have to log vag.
    just thinking what it "might" be
  7. wibble111
    wibble111 needs to scratch the itch
    841
    My moneys on either the lateral or longitudinal acceleration sensors, but as has been said the only way to know is to get it scanned for faults.
  8. thorsy22
    thorsy22 Member
    308
    I had this/got this, steering angle sensor, brake light switch and ABS controller all needed replacing.
    Really need to get it on VAGCOM to confirm what it is tho.
  9. mulli01
    mulli01 Member
    33
    i also had this problem, after hooking it up to vagcom it turned out to be a wheel speed/abs sensor
  10. mattyboy199
    mattyboy199 Well-Known Member
    1,897
    30
    have you removed your steering wheel ?
  11. myke
    95
    Wow .. that's a load of replys , it all sounded quite possible , to answer the questions
    No not had the wheel off , no cant turn ABS on I only have a button for traction control , I have been pressing it to turn traction control off .... and turning it back on as it goes way too quickly round bends for the poor little 16" wheels ! before this happened the traction control was cutting in way to early on right hand bends , I had thought it was after a 4 wheel alignment 12 months ago but not sure ...I have a feeling this was the steering angle sensor ..hope its not the abs controller as that sounds expensive !! as the brake lights work I guess its not the brake switch, anyone in the west midlands with vagcom able to run a scan for me , my MAC wont run vagcom ;o(
