About to start the retrofitting of the interior light pack......but.......
RobinA3 Jul 15, 2008
  1. RobinA3
    RobinA3 Well-Known Member
    1,828
    47
    i could do with the part number of the 'repair wire' which people use to connect to the electrical block under the steering column.
    I have bought all the lights etc to do the work so i just need the wire, i was hoping to be able to find something at work to do the job but failed...............
  2. Rabbit222
    Rabbit222 Active Member
    708
    125
    43
    Is this an easy job to do? Do you perhaps have a DIY as well as part numbers for the interior light pack?
  3. sakkie69
    sakkie69 2008 Audi S3
    199
    It's basically putting a light in each footwell in the 2-door cars, it's easy to put in. You can also replace the roof light unit (plug and play) to give some additional lights.
    The additional lights package is a bit harder to do (puddle lights, lights in doors, etc).
  4. Rabbit222
    708
    125
    43
    I'm keen on that :) You have any part numbers and a DIY?
  5. redbutcher
    redbutcher Member
    649
    I've just retrofitted the Aux in connection to my RNS-E and used the the following part number for the repair wire (thanks to MarcQ)
    000 979 009
    Should be about £1 from your local dealer.
  6. MarcQuinlivan
    MarcQuinlivan Active Member
    2,539
    There are numerous repair wires of all shapes and sizes.
    Here's the DIY for the footwell lighting: http://forums.fourtitude.com/zeropost?cmd=tshow&id=2536694
    looks like you need 2 of 000 979 133 and one of 000 979 131.
    There is also a hole under the front seats to install lights under them. All part numbers are in the DIY guide.
  7. RobinA3
    1,828
    47
    I'll be retrofitting the following this weekend
    Puddle Lights (underneath the door cards)
    Foot well lights
    Red Warning light (end of the door card)
    I'll do a DIY thing on it whilst i am doing it so i will post it on here.
    I have some spare lights (white footwell and puddle lights) which i got from Audi so if anyone wants any then let me know or else i'll put them on ebay. They were £7ish from Audi.
  8. sakkie69
    199
    You got part numbers for the puddle lights? Or are they same as the footlights?
  9. RobinA3
    1,828
    47
  10. RobinA3
    1,828
    47
    Does anyone know if i can feed all 6 lights from the single pin coming from that electrical block?
  11. MarcQuinlivan
    2,539
    That's what it seems to be suggesting.
    Did you read the bit where it said you should use some sort of shielded housing for under the seats to prevent them from catching fire? It recommends using boot light housing for under the seats.
  12. RobinA3
    1,828
    47
    I have got the wiring diagram for the interior lighting pack and the door puddle lights and warning lights run off a different pin, they don't all feed from one single pin. I think i'll do it properly and feed them off the correct pins rather than just one.
    Yeah i read about the sheild, i have got myself some lights which have a backing plate on them.
  13. RobinA3
    1,828
    47
    Right after a bit of investigation the whole job seems quite straight forward.
    If i were to get 'kits' made up for this modification would anyone be interested? The 'kit' will contain the following:
    Instructions
    All the lights (puddle, footwell, red warning)
    All the wiring cut to the correct lengths including the plugs to the electrical block and lights.
    so basically it would be a pretty much plug and play (having removed interior trim etc) apart from having the function turned on via vag-com.
  14. Scorpius
    Scorpius The S Factor
    82
    Looks a rather interesting mod. Anyone have a pic of an A3/S3 with puddle lights? Most cars I know have them on the side mirrors but it seems the A3/S3 has them on the doors. Would love to see what this looks like
  15. sakkie69
    199
    Just imagine lights in the door, at the bottom of the black plastic.
