a8 sport wheels on an a4
yendall24 Nov 1, 2008
  1. yendall24
    yendall24 Member
    571
    i have managed to get myself a set of a8 quattro sport alloys of ebay. i want to put them on my a4 will i need spacers to fit these onto an a4 if so do i need a spacer on each wheel back and front and how thick do they need to be
  2. Siena
    Siena Active Member
    2,626
    What's the offset of the wheels you bought?
    Or could you post up the part number of the wheels themselves?
  3. yendall24
    yendall24 Member
    571
    hi the offset is et48 the tyre size is 245x45x r18
  4. Siena
    Siena Active Member
    2,626
    You'll need at least 15mm spacers to fill the B5 arches.
  5. yendall24
    yendall24 Member
    571
    thanks for the info any idea where i can buy these from and will i need all 4
  6. aragorn
    18,036
    724
    arent the stock B5 S4 rims 17x7.5" at ET45?
    How wide are these 18" rims?
    Surely spacing the wheels out 15mm is going to put them pretty close to the arches?
  7. docurley
    4,070
    85
    The tyres are too wide and the profile wrong.
    I would say 235x40x18 or the norm would be 225x40x18
  8. aragorn
    18,036
    724
    i would imagine the tyres are so wide because the wheels are 8 or 8.5" wide.
    Fitting 225/40's to 8.5" wheels isnt really ideal and while it might work it wont give the best roadholding or performance from the tyre due to reduced sidewall compliance.
    Unfortunately i'd imagine that with such wide rims you have to compromise between the tyre fitting the rim properly, the rim/tyre catching on the suspension and the rim/tyre catching on the arches.
  9. aragorn
    18,036
    724
    a quick google suggests the wheels are 8" wide.
    The standard 16" A4 Sport alloys are 7" wide with a 45mm offset
    An 8" rim with 48mm offset will stick out 9.7mm more than the original rim (ie closer to the arch), and the inside will be 15.7mm further inwards (ie closer to the suspension).
    if you fitted a 15mm spacer as Siena suggested they would then stick out 24.7mm more than the OE rims (and be 0.7mm more inwards) This might mean they are very close, or too close to the arches and they may catch. Depending on how much clearance you need on the inside i would suggest trying to go for a thinner spacer unless you really have to goto 15mm to clear the suspension.
  10. docurley
    4,070
    85
    I ran 225x40x18 fine and even tracked my old 2.8 Supercharged A4 on them with no issues.
  11. 205man
    205man Active Member
    1,071
    13
    im running 18x8 inch rims at the mo and never had any problems although im not running 48 im on 35 if i remember correctly
  12. aragorn
    18,036
    724
    i've always been under the impression that the wheel offset should be kept as close to the OEM specification as possible.
    The design of the suspension relies quite heavily on the offset of the wheel rim, and changing it will affect the scrub radius as well as possibly reducing the life of the wheel bearings as the load is no longer spread across them evenly.
    I would suggest that unless you HAD to for reasons of them scrubbing/catching on the insides, i'd be keeping the offset as close to that original ET45 as possible!
  13. yendall24
    yendall24 Member
    571
    i have decided not to bother fitting these now so they are for sale cracking tyres 2 continental and 2 fulder 245/45/18 very reasonably priced send PM if interested
  14. ian52
    ian52 2000 a4 1.8tqs-yellow
    1,199
    did you get them off ebay last week?i was interested in them but would need to get rid of my current wheels.
  15. yendall24
    yendall24 Member
    571
    yes mate i did but be warned tyres are too big for an a4 as previous post suggest apparently wheels will fit with smaller tyres but i am not bothering
  16. ian52
    1,199
    if i had money i would buy them and get new tyres but i dont.i think they look good on a b5.
  17. yendall24
    yendall24 Member
    571
    fare comment its all about personal taste
