A8 D3 2003 Parking Sensor Problem - Help
shans211 Nov 4, 2009
  1. shans211
    shans211 Vrooom
    Hey all, hope someone could help me...I am having issues with my parking sensors, I have the parking sensor plus upgrade with graphic - issue is when i engage the sensors, the screen pops up with heavy static like on a badly tuned tv. I have the VAGCOM and it states that there is an issue with Middle Right Front Sensor - i have inspected it, replaced the sensor at a rediculous cost from the stealer and checked all contact points. But the problem still persists...
    the VAG COM displays the following:
    Wednesday,04,November,2009,19:29:40:27752
    VCDS Version: Release 908.0
    Address 76: Park Assist Labels: 4E0-910-283.lbl
    Control Module Part Number: 4E0 910 283 D HW: 4E0 919 283 C
    Component and/or Version: Parkhilfe 8-Kan H12 0050
    Software Coding: 0221008
    Work Shop Code: WSC 131071 1023 2097151
    1 Fault Found:
    01627 - Sensor for Parking-Aid; Front Mid-Right (G253)
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 156
    Mileage: 103390 km
    Time Indication: 0
    Date: 2009.11.04
    Time: 19:29:20
    Anyone able to decifer what it could be....I am considering purchasing a new harness as there could be a hairline split somewhere however the issue is only that one sensor (despite replacing it). Is there a way of coding the module to eliminate that sensor from radar checks? thats the easy way out but i would rather fix the problem....
    Sorry for the long post but its necessary...
    Thanks in advance
  2. s8craig
    1,745
    53
    I presume this is an upgraded system as the 2003 cars didn't have graphical parking, but you have a rev D controller from a 2009 car.
    Do you have a rear view camera? if not why is it coded for rear view camera?
  3. shans211
    shans211 Vrooom
    Thanks Craig, yes I have upgraded to the Rev D controller. Everything was working fine for months after installing the Rev D controller so i cant think if its that... I have ordered a new wiring loom for the sensors today, £100 again...hoping its a line break in the loom thats causing the issue. I hope this resolves the issue but if it doesn't i'd want to try and code the controller to eliminate the checks on that particular sensor...i giess its not that straight forward in reality...I was investigating the possibillity of fitting the S6 DRLs but after looking at the space and the size, realised it was not going to happen without major mods...I must have trapped a wire when putting the bumper back on...well i assume so...
  4. s8craig
    1,745
    53
    Yes, but 0221008 is coding for APS with camera, have you fitted the camera as it would switch to a blank screen if no camera present.
    I would think 0201008 is the right coding for APS without camera.
  5. shans211
    shans211 Vrooom
    Sorry forgot to say, no - no rear view camera....YET! I will book it in with you for that !
    When i fitted it, the coding was already set so the graphic just came up automatically.
    I will change the coding to what you suggest and give that a try...that should eliminate the issue of screen static then...just the sensor wire/sensor to worry about next...
  6. shans211
    shans211 Vrooom
    Thanks Craig I have changed the coding and thats eliminated the fuzz. I am just fitting the new loom now so lets see if that resolves the sensor malfunction...
  7. shans211
    shans211 Vrooom
    Thanks Craig, it was the wiring loom in the end... sorted... Best regards...
