A6 electrics
a6andy Feb 6, 2010
  1. a6andy
    a6andy New Member
    9
    can anyone give some advice please.......car has started to lock and unlock itself and putting all the windows down. its a a6 2.7t year 2000
  2. andyquattro
    andyquattro New Member
    21
    Are your keys always close by when this happens? Maybe it has sticky buttons!
  3. NHN
    29,328
    1,708
    Central locking module got wet or gone faulty, really needs a scan on the car for errors mate.
  4. mickel5
    mickel5 New Member
    22
    I agree, check for water entering the passenger footwell.
  5. alibob
    alibob Liskeard Classic Cars
    46
    Hello a6andy
    Check out my last 3 (?) threads. I have tried all of the advice given and can't trace the fault on mine. I have noticed that I have no power to the boot light anymore and it definitely gets worse the colder it is. I hope you find the answer and can throw a bit more light on the problem.
    alibob
  6. a6andy
    a6andy New Member
    9
    the boot lights work but the rear ones dont and the boot release has stopped working. got it in the garage at the moment,will let you know if they find anything.
  7. alibob
    46
    a6andy...Have you had any news yet?
    Mine has completely cured itself (so far) but as it is getting cold again I am waiting for trouble!
    I still haven't traced the boot light fault either.
  8. a6andy
    a6andy New Member
    9
    All sorted at last turned out to be the front door lock assembly £130 fitted good luck
  9. alibob
    46
    Hello a6andy
    I spoke too soon. Had a deluge for the last couple of days and the shenanigans have started again.
    I presume it was the drivers dooor mechanism? How much did the actual part cost because I should be able to change the mechanism myself.
    Al
  10. a6andy
    a6andy New Member
    9
    Hello mate not sure how much it was on its own had a few other jobs to do aswell sorry
  11. mcsweedler
    mcsweedler New Member
    Hi there, you said it got worse after heavy rain, this is a common fault on A4 & Passat and possibly some others. Its caused by water ingress into the passenger foot well because it runs over all the wires behind the panel on the left hand side. Its an easy fix just remove the pollen filter housing and put a generous bead of silicone around the foam seal that goes between it and the car and Bob's your mothers brother !!
    Hope this helps
