Hi and help
Just bought above car and plugged in VAG com.
6 Pcodes present
P00523
P00532
P00550
P00575
P00667
P01376
All appear to point to wiring.
Also Noticed that coolant temp was low at 41 deg and gauge showing 90 deg.
All terminals on coolant sensor were corroded and full of water, Have swapped it and now seems to read senseable values. Power seems to have improved but still white smoke.
Appear to be lacking in boost, if you flor the throttle there is a big flat spot at 3250rpm
Will investigate further to any loose fitting turbo hoses and will check MAF sensor
Think the engine is ABF.
When sorted how do I get more power?
At a sensable cost.
Please help and thanks for looking
6 Pcodes present
P00523
P00532
P00550
P00575
P00667
P01376
At a sensable cost.
