A6 BOSE System With Sony headunit Problem
rich dj Jul 28, 2006
  1. rich dj
    rich dj Active Member
    265
    26
    I have an A6 Avant with a Bose upgrade and have removed the Audi Bose head unit and replaced it with a Sony CDX DAB 6650 and the connection leads with 4 rca (phono plugs) to plug into the sony pre outs and no speaker outs at all, it all works but you get a very loud click when track skipping or changing audio settings as if the sony is not muted during these fuctions.
    Has anybody come across this problem before or any ideas.
    ps i am and have been an audio engineer for 20 years so im not clueless.
    :keule:
  2. AndyMac
    9,832
    45
    No it's normal unfortunately. The Bose amp has a wierd capacitor setup on its input stage to filter electrically noisy processes on the Audi HU. So when an aftermarket HU mutes the RCA's (like any HU should) it discharges the capacitor array and thus the loud pop or click you are experiencing.
    The only way round it on the Bose setup is to use the speaker input adapter rather than the RCA input adapter. This plugs into the speaker outs of the HU and uses a hideous hi/lo or line out convertor to take the speaker level back down to pre-out level. Obviously from an SQ perspective it is not recommended but it is the only way to get rid of the popping.
    The only other alternative is to replace all the speakers and either wire them up directly to the HU and/or invest in a proper amp. The Bose speakers a re 2ohm impedance so the HU won't like driving them directly.
  3. rich dj
    265
    26
    bugger nothing is simple.
    i dont think i want to go down the speaker to line level adaptor way.
    i may have to modify the bose amp if i can get hold of a circiut diagram for it,
    so no mp3 or Dab for me yet then.
    Anybody help with diagrams?:keule:
  4. AndyMac
    9,832
    45
    Sorry you had to find out the hard way (like me).
    There was a tech article on AW about removing the capacitors but I can't find it now, but I remember the guy said it wasn't worth it in the end.
    Honestly the line level convertor method is surprisingly OK and by far the easiest option, I'd give that a go first before reaching for your soldering iron!
    But by far the best method would be to replace the Bose speakers and run them off the HU, the Bose system really doesn't like being interferred with and when you see the "quality" of their paper cone speakers it's amazing it sounds as good as it does, the tweeters they use aren't even Bose they are the same Nokia **** as the non Bose setup.
  5. rich dj
    265
    26
    mmm
    thinking going on, ok i have replacement mac audio speakers seperates, the high end ones i could put them in the front and drive from the head unit but then i would have to put wires to the door or find the bose amp and connect to the lead there(assuming i can find it first any ideas) or just replace the bose amp with a 2 ohm rated amp x4 outs, the other things i was going to try before doing this was try a couple of ground loop isolators in line to the front and rear outs to take out the dead short of the mute or to add in line a couple of capacitors to do the same thing, any body tried this.
    i also spoke to my local in car fitting company and was told that "yes this happens somtimes on Sonys but my Alpine works fine and buy another head unit mate" that did not go down very well as i am very pleased with my Sony unit
    so the only thing i could come up with was the Alpines output was capacitor coupled and Sonys was not, i still have to speak to sony technical as yet will do this monday, although i dont hold my breath as they were usless on help getting correct plug for DAB aerial connector, i will also look at the sony service manual when i tap up an old colege for a favor ,
    any more help would be greatfull, I will keep you informed,
    I DONT GIVE UP VERY EASELY:tocktock:
  6. AndyMac
    9,832
    45
    No you'll get the same result with an Alpine HU (the one I used was Alpine), it is the Audi kit that is not in line with the industry standard for muting the pre-outs. Nice try by the dealer though, trying to sell you a new HU.
    The only HU that might be more compatible would be a Blaupunkt as they were the original HU's fitted in Audi's and they still use the stupid mini ISO connector for the pre-outs. My DAB unit is a BP but, from previous experience, I'd already decided to rip out all the Audi kit before I started so not sure if it would make a difference.
    No idea if a ground loop isolator would help, worth a try.
    The Bose amp is in the trunk, so not too difficult to link up the speaker outputs.
  7. rich dj
    265
    26
    also tried kenwood HU supossed to have the best ground isolation still the same...
    ok so tried ground loop isolators this works no clicks but...
    now sounds all over the place front and rear and left and right not all in phase
    frequency responce curve on these ground loop isolators is all over the place.
    they were cheap ones but this is not the way to go
    Next...tried isolating the ground on the phono leads....next
    Sounds realy good if you just plug in the phono leads shame about clicks,
    now trying a capacitor in line with the signal leg of the phono leads if this does not work then speaker line level convertors from autoleads
    let you know how i get on :keule:
  8. rich dj
    265
    26
    ok after much messing around popping and such like i placed many different capacitors and found by putting a 15uf capacitor in line with phono plugs no clicks and no apparent loss in sound quality, did not have time to make full adaptor leads up to give road test but i will tomorrow when i pick up some phono plugs and sockets to fit caps in.
    Nice simple filter dc to about 40hz ish..
    i will give a good test and let you know.
    ps another anoying thing is i have to take the face off when the cover on dash goes over...
  9. AndyMac
    9,832
    45
    Nice one! Well done, you may have to market such an adapter!
  10. rich dj
    265
    26
    the only thing i forgot to test is the amp rca ground the same as the HU rca ground potential,
    i will road test tommorrow and let you know
    also i spoke to a car radio fitter and told him my outcome and he said he has a high quality ground loop isolator available at £20 which would do the same job as long as there are no phase differances and a flat responce.
  11. S4_SAT
    S4_SAT Stuck in 3rd
    74
    Could you help me, I have this problem with my Audi A2. I have tried everything else but it still makes a loud popping sound. Would you be able to send me a list or the bits needed and a wee how-to-do for it please? :thumbs-up:
  12. rich dj
    265
    26
    ok will send you details diagrams ect very simple you just need to know how to solder on phono plugs and sockets to screened cables and put capacitors in line in the plugs.
    still no road test yet, car away having new radiator fitted now on 3rd day away should be back today sometime.....with any luck
  13. S4_SAT
    S4_SAT Stuck in 3rd
    74
    Would this fix it as well? Have you got a part number for it if it made by autoleads?
  14. rich dj
    265
    26
  15. AndyMac
    9,832
    45
    If it's made autoleads then it's guaranteed not to work
  16. rich dj
    265
    26
    just making up leads now in front of pc.
    i need 4 phono leads some only need 2 depending on model
    i need a web space to send my photos to get on this site any ideas
  17. AndyMac
    9,832
    45
  18. rich dj
    265
    26
    thanks andy
    see pictures i will let you know if it works ok tommorrow need to have wife time.
    ps capacitors 15uf 16v electrolitic
    Tools requied
    soldering iron
    solder
    pair wire cutters
    electrical insulation tape
    pliers (with an elastic band on the handle to hold plugs so you dont get burnt)
    screened cable
    4x phono sockets
    4x phono plugs (i used angled to get stereo to go in further and to fit in capacitors)
    15uf ish capacitors in line pref
  19. AndyMac
    9,832
    45
    Very neat
  20. rich dj
    265
    26
    been busy all weekend may have time tue night sorry
  21. rich dj
    265
    26
    ok fitted in tested ok on road as well all ok.
    poss slight loss in low bass very small mind you, when i have more time will do comparisons.
    Very slight click now when skipping tracks but i mean very slight.
    PS i am very fussy when it comes to audio.
    I HOPE THIS HELPS PEOPLE SORT THIS STUPID NON STANDARD PROBLEM OUT WITHOUT REMOVING BOSE SET UP.
    Now all i have to do is change the factory fit aerial for my DAB replacement type and run additional aerial lead for DAB and we have digital radio and MP3
    :rockwoot: :smile: :yes: :arco:
