A6 Avant quattro rear discs question
Inskip75 Jan 10, 2010
  1. Inskip75
    Inskip75 Member
    94
    I've a 2003 2.5 TDi Avant quattro and the rear discs are due for replacement, so looking at after market Brembo site I see there were 245mm and 255mm diameter discs for this model - this explains the rust on the outside edge of current discs, which are 255mm but should be 245mm. :sadlike:
    Anyone know which models the 255mm were fitted to and if its only the caliper carrier which needs changing to use 255mm discs - I know its only 10mm but if its dead easy why not?
  2. etronic
    etronic TDI
    69
    Send VIN so we can check what discs you should use.
