A6 2.5tdi egr removal?
Ianb4310 Jul 1, 2012
  1. Ianb4310
    Ianb4310 Member
    66
    Hi is it worth blanking off the egr valve with just a plate or should I get a bypass kit or just not bother I've had it stage 1 remapped
    Ian
  2. abdul h ghafoor
    abdul h ghafoor Member
    52
    I blanked my eye of with q plate from eBay. I found the car more responsive and as yet no probs.
  3. Ianb4310
    Ianb4310 Member
    66
    Cheers I'll order one
  4. myth
    myth Member
    157
    I plan to shut off my EGR too on my 2.5 tdi and for that, I have 2 types of questions:
    1. What are the drawbacks? What about the advantages?
    2. How should I remove it? Simply block the vacuum line, or buy blocking plates?
  5. danhar707
    danhar707 New Member
    15
    downside....NOx emissions go up, polar bears die. ecu Might get a bit confused and order up a derate, but probably not on a euro3 engine.
    plus side... better fuel econ and performance
  6. myth
    myth Member
    157
    So, I don't care about the NOx emissions. The engine is euro2. So I should go ahead and do it?
    How it's best to do it:
    a) physical remove
    b) remove via vag
  7. wesmaster
    wesmaster Member
    300
    20
    Just blank it off at both ends, should need to map it out, being e2.
    plates available on ebay, gaskets from TPS. shouldnt cost any more than £10. Dont forget to blank off vacuum hose which goes to EGR valve.
