A6 2.5tdi egr blank or removal bkc engine
Ianb4310 Jun 30, 2012
  1. Ianb4310
    Ianb4310 Member
    66
    As the title says I'm interested in blanking off or removing the egr valve from my 2002 A6 2.5 tdi has anyone done this ?
    Is it easy are there any "how to" on here been searching but not found any
    Any help please
    Ian
  2. abdul h ghafoor
    abdul h ghafoor Member
    52
    I have a 2000 2.5tdi. I blanked mine of and it took around 10 mins. Just removed the engine cover off, removed the 2 bolts from the egr valve which loacte the pipe to valve, slipped in plate then reversed procedure.
  3. Ianb4310
    Ianb4310 Member
    66
    Cheers I'll order one
  4. Bomberclot24
    Bomberclot24 New Member
    What's this? I could google but what's a forum for if u can't ask a question. Lol.
  5. ms1083
    ms1083 Member
    148
    I am considering this too. Please can you explain what the advantages are of doing so & if there are any disadvantages. I would espcially like to increase my mpg - does it do this? My car is 2.5 V6 Tdi 2004 A6 Allroad (BAU engine). Is the increase in running temperature of the engine an issue?
    seems v easy to do, saw a picture of how to do it on one of the listings on ebay for the blanking plates, simply loosen the 2 hex bolts on end of pipe leading to EGR valve and slip in the blanking plate (it has slots so it can slip in rather than having to remove anything).
  6. adamss24
    adamss24 Well-Known Member
    4,584
    407
    Your's will flag an emission related code and it will put the engine management light on the dash. Your's need the EGR settings deleted in the tune so a remap is the way forward !
