A5 cruise control retrofitting
Dave_71 Mar 26, 2011
  1. Dave_71
    Dave_71 New Member
    I just fitted a new set of steering column switches including cruise control to my 08 A5 and im now having some problems getting it recognised by the engine ECU with VCDS / VAG-COM.
    I enabled the cruise in the steering wheel, and engine codes, and have confirmed that all of the switches on new the new stalks work and show up in VAG-COM.
    I tried the login codes for enabling cruise on the ECU (11463 ?) but it isnt accepted by the car.
    Any suggestions ?
  2. jb0o
    jb0o North East Forum Moderator Regional Rep Site Sponsor VCDS Map User
    2,662
    116
    Is an error coming up when you enter the '11463' code, or is it accepting it and just not working?
  3. NHN
    29,284
    1,695
    Any codes thrown?
    Also given newer car, check in say central electrics for any long coding etc for cruise enabling.
  4. s8craig
    1,740
    53
    11463 is only for the older cars, new A4/A5/Q5 are a different kettle of fish. Sorry I can't help you with the coding AFAIK it's all done with SVM codes online now. If you can get a friendly techie to enter the SVM code for you online it's 050 050 from memory.
  5. jb0o
    2,662
    116
    I fitted CC to a MY10 S3 the other week and the login-11 was greyed out, so it was impossible to enter the 11463, instead I had to use the coding-07 to select 'Cruise Control Installed'.
    Have a look in the coding-07 of engine-01 and see if theres anything there about CC. In the MY10 S3 there was a long coding helper within the coding.
  6. NHN
    29,284
    1,695
    Yeah newer 8P's are different, why they did it via security access in 1st place makes me wonder.
