A4 wheel fitment on my A3
WALTO TDI Dec 6, 2012
  1. WALTO TDI
    WALTO TDI Member
    293
    12
    hi guys ive seen a set of alloys i like from an A4.
    The size is 18 x 8.0 with an offset of ET47.The centre bore is 66.5
    will i need spigot rings?
    will these fit under my rear arches as my A3 is lowered?
    i currently have standard 5 spoke s line wheels with 10mm spacers on the rear.
    i am puzzled with the offest and wheel width so any help is greatly appreciated
  2. BigWillyStyle
    BigWillyStyle Member
    566
    58
    Bore for an A3 is 57.1mm i believe and the ET should be between 45-50. What is the PCD? 5x110 or 112?
  3. OCD-A3
    OCD-A3 Member
    118
    That offset is fine, and the rears will fit without the spacers. As BigWilly said, our hubs are 57.1, so you will need rings. And all A4s back to the B5 gen are 5x112 so that won't be an issue. I'm guessing that with a larger hub bore these are off a B8?
  4. WALTO TDI
    WALTO TDI Member
    293
    12
    2012 plate A4 mate. so i will need spigot rings from 57.1 to 66.5, but the offset and rim width are fine?
  5. BigWillyStyle
    566
    58
    Offset and width is fine. I have 18x8.5J on my A3 :arco:
  6. OCD-A3
    OCD-A3 Member
    118
    Yes :thumbup:
