A4 Turbo replacement.
Discussion in 'A4/S4 forum(B5 Chassis)' started by Lukie, Sep 25, 2010.
  1. Lukie
    Lukie New Member
    Sep 25, 2010
    I have just found this site and hoping for some info. I'Ve had my turbo cut out a couple of times and the Audi garage diagnosed a fault with the waste gate actuator, they say a new turbo is required. It is a 1.9tdi sport on a 53 plate with 26,000 miles only. It seems a bit early in its engine lifespan to need a new turbo, so I wonder if anyone else has had a similar problem.:ermm:
  2. Advert Guest Advertisement
  3. auroan
    auroan Active Member
    Jan 28, 2004
    You might be better off asking this in the B6 section if it's a 53 plate. Also try an independant VAG specialist garage as well.
