a4 tfsi timing chain
sewell10 Apr 2, 2011
  1. sewell10
    sewell10 Member
    236
    as above has any one had to change one if so at what cost i thing mine is slightly noisey
  2. Paul N Ireland
    Paul N Ireland Member
    95
    Oh yes, I done mine when I first bought it. I have no idea about labour costs as I done my own at the time of timing belts ect but I would expect to pay around the £200 range. The chain and tensioner from memory is around £100 - £150
  3. Marrow
    Marrow Member
    587
    2.0tfsi has a cam belt doesnt it not a chain? Some one more technical may correct me though but thats what I had changed by local indy!
    Your looking at arround 300 but I dont think you should change it unless due no point bare in mind the tfsi engine is noisy at idle even when healthy I think its some thing to do with the fsi technology I seem to remeber reading!
    If you do get cam belt changed make sure water pump is done at the same time!
  4. hades-
    9,480
    646
    marrow the tfsi has a belt and chain
    parts around 150 and prety easy to change but tight
    around £300 in labour to change
  5. Marrow
    Marrow Member
    587
    See I told you someone more technical would correct me ! lol
    When should chain be changed then ?
  6. Paul N Ireland
    95
    Just when it starts rattling. If it does not rattle, you dont
  7. sewell10
    sewell10 Member
    236
    the chain rattles only on over run
  8. hades-
    9,480
    646
    are you sure its the chain thats makeing the noise ?
  9. sewell10
    sewell10 Member
    236
    sounds like the chain and tensioner thanks
  10. Chris79
    Chris79 On my 3rd A4! RS4 next???
    159
    But the tfsi uses a belt!
  11. Paul N Ireland
    95
    They use a belt for cam to crank timing but the two cams are linked at the rear of the cylinder head by a chain
