A4 TFSI slight hesitation as revs normalise to idle
prel2000 Feb 24, 2012
  1. prel2000
    prel2000 Member
    67
    My 2.0TFSI Avant Quattro (manual) is experiencing slight issue as the revs normalise back to idle.
    I experience this whilst in traffic (on and off the acceleration) or as I approach lights to come to a stand still. The engine seems to fluctuate in revs for about a second before normalising to 800rpm. Its fine once it gets moving - theres no loss in power or hesitation and the car has never cut out. I have only been experiencing this in the last 2 months or so.
    The car has done 81,000 miles and has a full history. Remapped by AMD and has the revised diverter valve.
    Ive not had it in to get it checked over, just yet. However, I have a OBD reader and there are no faults logged.
    Has anybody experienced this or have an idea where the problem lies?
    Thanks in advance.
  2. solaris
    solaris Member
    416
    17
    Its tough to say without fault codes however the pcv may be on the way out, the stock one is poor anyway so may be worth changing this and/or inspecting the pipes to eliminate it. Basic sysmptoms are eratic idle, boost loss, oil leak so it would be a good starting point.
    Get well soon :happy:
  3. suckedin
    suckedin New Member
    25
    Hi,
    Does it seem to 'hold on to the revs a bit' also when you press the clutch down between gear change? Mine does both of these and I've been to told it's the clutch switch. I've just not got round to changing it yet.
  4. hades-
    9,481
    646
    i had this
    clutch switch was at fault
  5. solaris
    solaris Member
    416
    17
    This may be the part number for the clutch switch 7H0927189
    Also a picky of where it goes (Number 2)...seems to be a simple enough swap
  6. razza1
    razza1 Well-Known Member
    3,054
    804
    Might be carbon build up on the throttle body (think it was there....), had this on my old one and caused it to hold revs a bit longer.
  7. Craig Cull
    Craig Cull Well-Known Member
    2,311
    1,106
    I have exactly the same problem with mine at the same mileage. Is the clutch switch always the case? Or could it also be other problems? Hope you manage to get it sorted mate :)
  8. mancdan
    mancdan Active Member
    485
    50
    I also get this issue from time to time, usually only when changing from first to second.
  9. prel2000
    prel2000 Member
    67
    Hi All, just to give you an update on this.
    It was the indeed the clutch switch at fault. Did attempt a clean of the throttle body at first but didn't fix and then swapped out the clutch switch and problem sorted.
    Thanks to all that suggested this as the mechanic wouldn't never had thought of that and no fault codes logged to point in that direction.
    Car does appear to be running smoother due to the throttle body clean, so maybe worth doing both if you are experiencing a similar issue. Bare in mind that throttle body may need adaptation after clean.
  10. mancdan
    485
    50
    Was the clutch switch easy to replace and what was the cost of the new part?
  11. prel2000
    prel2000 Member
    67
    About 15 mins to replace.
    Part was 13 + VAT.
  12. mancdan
    485
    50
    Did you get part from ebay or Audi garage?
  13. Craig Cull
    2,311
    1,106
    just done mine as a result of this post and its sorted the problem. cost me £16 from audi took me 5 mins to change. cheers :)
  14. prel2000
    prel2000 Member
    67
    Still experiencing similar issues although not as bad.
    The symptoms are of a slight miss at idle when depressing clutch, turning the steering wheel when stationary, using the electrics inc central locking. Its almost like there isnt enough power in the battery or alternator isnt doing its job. Did a battery check and it came up as 13.8 which is normal, no?
    Any help would be appreciated...
