A4 TFSI dead? Dash lights on, then died, now wont start!
S-Liner Jul 12, 2013
  1. S-Liner
    S-Liner Member
    31
    Hi,
    Need some advice: travelling on motorway yesterday and suddenly my dash lights came on and the oil pressure light. Power steering and brakes were lost as the engine died. It now turns over but wont start?
    Cam belt intact, it didnt drop oil.
    Could this be fuel pump, oil pump, alternator?
    Any help appreciated!
  2. sewell10
    sewell10 Member
    236
    Get it code read
  3. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,819
    197
    As above, find someone local with vcds
  4. g60jet
    g60jet Member
    145
    my bet is you've blown a cold pack and its taken out the engine managment fuse. You will need a 30amp fuse iirc, and you need to take the wipers and scuttle off, the fuse is under the ECU. cheap fix. but beware if its a coil pack, it will blow again. smell each coil pack for the burnt one.
  5. S-Liner
    S-Liner Member
    31
    Thanks for advice guys, it was actually more serious and as a result im looking at a new engine. The local specialist garage tested the compression and it was very low, they stripped it and found the head was scored and the cams at the back of the head were worn. The timing was out and they suspect that the cam chain skipped and knocked its timing out, bending a valve. The oil pump also appears to have failed. Im looking at getting a good second hand engine but can only find one with different codes currently, im assuming the different codes (but same engine) are interchangeable?
