  1. t2myd
    t2myd Member
    167
    what engine code will a 1999 v reg a4 tdi 1.9 be anyone know ?
  2. yabbadoo
    yabbadoo New Member
    hazard a guess at AFN
  3. moschino
    moschino Member
    252
    If its the 110bhp model then it should be the AFN engine as advised above.
    You should have a lable in the service book that states what engine code you have. If you have lost the service book then there is also a label where your spare wheel is located.
  4. Nessy
    Nessy VW + Audi mad
    939
    89
    On the top of the plastic cambelt cover housing there should also be a bar-coded sticker which lists the engine code and number..........
    If its a '99 AFN the engine noise insulation cover should have a red letter 'i' on the TDi motif, although as the cover is so easy to remove it shouldn't be taken as 100% that the cover is original to the car...........
